I am currently exploring the idea of using Ikea Metod components for DIY upcycling projects and am looking for recommendations on which parts of the system are particularly well suited for this. I am interested both in the modularity of the elements and their material properties and flexibility regarding individual modifications and redesigns.
Specifically, I would like to know which Metod components are easiest to work with, for example, for cutting, adding cutouts, or creatively converting into furniture pieces outside the kitchen. It would be helpful if you could share examples of how you have successfully repurposed individual elements or any issues you have encountered with certain parts.
Are there components that are less suitable due to their construction or surface finish? And what about the fronts: Are they easy to paint or print on to customize the style?
I look forward to your experiences and insights!
Hello Amidben,
your question is very well phrased and gets straight to the point when it comes to using Metod for DIY upcycling. Basically, the carcasses (the boxes in which the drawers or compartments sit) are very sturdy and made of high-quality particleboard, making them ideal for repurposing.
Here is a brief guide on what to pay attention to:
- Carcasses: These can be fairly easily cut or drilled, but you should definitely ensure clean cut edges, as the melamine coating can chip otherwise. Use a fine-toothed saw blade.
- Fronts: The smooth surfaces can be prepared well with sandpaper and can then be painted or coated nicely with acrylic paint or special wood varnish. For printed or foil-coated fronts, it is recommended to sand the surface first to roughen it up.
- Doors and drawers: These can also be modified, but mechanical parts (drawer slides, etc.) are often a bit fiddly. It’s best to remove them completely before working on them.
A practical tip: For example, I made a seat stool from a Metod wall cabinet by shortening the carcass slightly and adding a padded lid. I removed the back panel and inserted an additional brace – this keeps the whole thing stable.
However, avoid using the plinths (baseboards/kickboards) and the fixed, screwed fittings, as these are usually less modular and more difficult to adapt.
Hope this helps!
Hope this helps!
KODAN32 schrieb:
Cabinets: These can be cut or drilled relatively easily, but you should definitely ensure clean cut edges to prevent the melamine from chipping.This is a crucial point. If you cut Metod components, it is advisable to use a circular saw with a carbide-tipped blade designed for composite materials or a Japanese pull saw with fine teeth.
KODAN32 schrieb:
For printed or foil-coated fronts, it is recommended to first sand the surface to roughen it.I would add that especially when painting the fronts, priming is necessary to ensure better adhesion and to avoid chipping of the new paint layer.
Furthermore, the narrower cabinet versions are especially suitable for smaller upcycling projects because they are lighter and more flexible in design.
The side panels (Metod side walls) can also be easily cut and reused as dividers or decorative elements.
In summary: For upcycling, the cabinets are the best candidates due to their sturdy construction, fronts offer creative potential through paintable surfaces, and smaller cut-offs from leftover parts can be used in many ways.
Amidben schrieb:
Are there parts that are less suitable due to their design or surface?Yes, I can answer that with a cheerful “Yes, definitely!” Baseboards and connectors are not very adaptable – they tend to be the divas of furniture construction and are hard to modify.
But hey, don’t let that stop you! The charm often lies in improvisation. I once transformed a Metod drawer into a stylish shoe rack and enhanced it with a few brushes and paint. The smooth fronts are actually great as a base for personalization. A bit of sandpaper, some acrylic paint, a little creativity – and your old kitchen module gets a second life.
You just have to enjoy experimenting, and upcycling will work out fine!
