ᐅ Which IKEA Metod drawers are especially durable?
Created on: 7 Nov 2021 09:37
janindo
janindo
7 Nov 2021 09:37
I am currently planning a kitchen renovation and considering the IKEA Metod drawers. My specific question is: Which IKEA Metod drawers are particularly suitable for heavy loads when you intend to store heavy kitchen utensils such as large frying pans, pots, and various appliances? I am not concerned about the appearance or the soft-close function, but specifically about the maximum load capacity and durability of the different drawer types. Are there differences in load capacity within the Metod drawer system depending on the material or construction? Perhaps someone also has experience with additional reinforcements or versions that should be preferred for installation? It would be great if someone could provide detailed advice on this.
gasidney
7 Nov 2021 10:12
The most durable drawers in IKEA Metod are those with metal sides. Standard fronts are made of wood, but the load capacity mainly depends on the drawer system rather than the front material.
PULAU
7 Nov 2021 11:45
Regarding load capacity specifically: IKEA usually states the maximum load for Metod drawers as 15-25 kg (33-55 lbs) per drawer, depending on the design. Metal-sided slides (i.e., full-extension slides with metal runners) are more durable and allow full loading without bending. Additionally, the lower drawers are generally more robust than the upper ones due to higher sidewalls and a sturdier construction.
FRANCISCOP
7 Nov 2021 12:03
As an addition: With IKEA Metod, the difference in load capacity is mainly determined by the drawer slide – for example, the 'Maximera' drawers are particularly durable because they have sturdy metal sides and robust rails. According to the manufacturer, they support up to 25 kg (55 lbs). The less expensive slides made of plastic or thin metal are less durable, especially under constant heavy load.
janindo
7 Nov 2021 13:27
Could you explain that in a bit more detail? I mean, are there specific models or categories at IKEA that are generally considered more durable? Or are the drawer slides similar across the board? I am particularly interested in whether there are differences for an 80cm (31.5 inches) wide drawer, since larger drawers often have to support more weight.
Repar
7 Nov 2021 15:14
In general, wide drawers with reinforcements or an additional center support are more stable. For 80cm (31.5 inches) drawers, I recommend the version with metal sides and full extension. This improves the load capacity.
