ᐅ Which hinges are suitable replacements for Ikea BESTA when the original ones are damaged?
Created on: 25 Feb 2019 18:37
kareem
kareem
25 Feb 2019 18:37
Hello community,
I have noticed that some of the original hinges on my Ikea Besta cabinet have worn out after years of use. Since I don’t want to replace the entire cabinet, I am now looking for suitable replacement hinges that are compatible and easy to install.
It is important to me that the replacement hinges match the typical drilling pattern and mounting points of the Besta system, preferably also compatible with the quick-assembly system that Ikea often uses. Additionally, I want to ensure that the doors continue to close properly and that durability is maintained.
Can anyone offer advice on which hinges work well as replacements for Ikea Besta? I would also appreciate experience with alternative brands or generic products. It would be great if you could suggest different options and briefly explain what to look for when choosing hinges to avoid buying the wrong ones.
Thanks in advance!
floga
25 Feb 2019 20:03
I can completely understand how frustrating broken hinges on a familiar piece of furniture can be.
I also once looked for replacements for my BESTA cabinet doors. What helped me was this: original IKEA hinges are often hard to find individually and can be expensive.
That’s why I decided to go with hinges from Hettich, as they are quite similar and have a good reputation. However, you need to carefully check the drilling pattern and the hinge mechanism, otherwise they won’t fit properly.
To avoid a tricky installation, I would also recommend removing the old hinges very carefully and noting down all measurements. When fitting the new hinges, pay close attention to the angle and door position to ensure everything closes flush.
If there are any new ideas, I’m curious to hear them!
mesila
26 Feb 2019 07:29
Regarding the question "Which hinges fit as replacements for Ikea BESTA when the originals are defective?" I can provide the following structured information:
1. Order original replacement hinges from Ikea: This is the safest option. Ikea usually uses a special clip-on hinge system that is perfectly matched to the BESTA system. The downside: these are available only through the Ikea online store or customer service and can be more expensive.
2. Hettich or Blum hinges with similar drilling patterns:
- Hinge boreholes (usually 35 mm diameter for the cup hole)
- Hole spacing (generally 37 mm for Ikea)
3. Purchase and installation:
- Important: Select hinges with a quick-mount clip to keep the doors easily removable.
- Pay attention to the opening angle (typically 110 degrees for BESTA)
Common mistakes:
- Confusing hole spacing results in incompatible hinges
- Choosing the wrong hinge type (clip-on vs. screw-mounted)
Summary:
If you are looking for an affordable replacement, you can use Hettich clip-on hinges with identical drilling dimensions. For the perfect fit, buying the original Ikea hinges is more expensive but carries the least risk.
Verify all measurements based on the cup holes and installation using a caliper!
Dwight49
26 Feb 2019 11:46
Specifically regarding the compatibility of hinges for the Ikea BESTA system:
- Ikea usually uses a standard size pivot hinge for BESTA with a 35 mm (1.4 inch) hinge cup diameter and a 37 mm (1.5 inch) distance between the mounting holes.
- The hinges often feature a quick-mounting system (clip-on), which should be taken into account when considering alternative products.
- The opening angles are mostly 110° or 120°, depending on the model, which is important for smooth operation.
- Replacement with brands like Hettich or Blum is possible if the measurements match exactly. These manufacturers often offer hinges with clip-on systems and the appropriate drill patterns.
- It is important to ensure that the hinge cup fits precisely at the mounting points, as otherwise the doors may not close properly or the cabinet can be damaged.
Conclusion: Original hinges ensure optimal fit, but can be replaced by high-quality hinges from Hettich or Blum with identical drill patterns and clip-on systems.
Gaupin68
27 Feb 2019 08:17
Hettich clip-on hinges fit.
Important: 35 mm (1 3/8 inches) borehole, 37 mm (1 7/16 inches) hole spacing, and clip-on mechanism.
Blum can also work but is less compatible.
Original brand costs a bit more, but fit is guaranteed.
Svenja7
28 Feb 2019 14:22
mesila schrieb:
3. Purchase and Installation:
- Important: Use hinges with quick-mount clips to keep the doors easily removable.
- Pay attention to the opening angles (usually 110 degrees for BESTA)
I would like to add: If you choose alternative hinges, be sure to check whether the hinge is suitable for the door thickness. Ikea BESTA doors typically have a thickness of about 16-18 mm (0.6-0.7 inches).
Furthermore, it can be helpful to buy a sample hinge before placing the final order to test the fit.
Also, during installation, you should not only pay attention to the drilling pattern but also to the adjustment options of the hinge. Good replacement hinges allow fine tuning in several directions so that the door fits perfectly and closes properly.
For those interested: I installed older Hettich hinges I had on hand, which fit exactly, and I didn’t even have to drill new holes.
