I am planning to retrofit doors on my IKEA Billy bookshelf and have noticed that there are different types of hinges that can be used for this. Since both functionality and durability are very important to me, I would like to ask the following question:
Which hinges are best suited for Billy doors when looking for a long-lasting and sturdy attachment, ideally also offering the convenience of concealed hinges?
I would like to know which hinges have proven particularly reliable, if there are materials that should be preferred, and if there are any special tips for installation, especially for someone with limited experience in fitting furniture hardware.
Looking forward to an informed discussion and helpful recommendations!
draneo schrieb:
Which hinges are best suited for Billy doors if you are looking for a durable and stable mounting while ideally also wanting the convenience of concealed door hinges?Hello draneo!
I think you’ve already summed it up quite well. From my own experience, so-called "cup hinges" (also known as concealed hinges) are definitely the best choice for Billy doors. They not only look great because the hinges are hidden from view, but they are also quite sturdy and often allow for slight adjustments in multiple directions, which really makes installation easier.
I used IKEA’s standard plastic cup hinges myself, and they do a decent job. But if you want a more long-term solution, you might want to look into high-quality metal cup hinges, which often include a soft-close feature. It’s really convenient because you don’t have to slam the door anymore 🙂
A small tip: When drilling the holes for the hinges, I’d recommend taking careful measurements and working precisely—it will save you a lot of effort later when aligning the doors.
Good luck with your project!
draneo schrieb:
Which hinges are best suited for Billy doors if you want a durable and stable attachment while ideally also having the convenience of concealed door hinges?Hello draneo,
to answer your question precisely: For Billy doors, concealed cup hinges with a 35 mm (1.4 inch) diameter are the best choice. These are standardized, offer very good load capacity, and are easy to adjust.
I recommend metal cup hinges with a spring mechanism to ensure long durability. A version with a soft-close feature is also advisable, as it extends the door’s lifespan by preventing loud slamming.
Additionally, pay attention to proper installation: The hole spacing on Billy furniture is usually predefined, so you should buy hinges that fit exactly to match the hole pattern. It is also helpful to secure the hinges with reinforced mounting screws, especially if the doors are frequently used.
In summary:
- Cup hinges, 35 mm (1.4 inch)
- Metal with spring mechanism
- Soft-close optional
- Pay attention to exact hole spacing
If you need more detailed advice on installation, I’m happy to provide further tips.
SONLIS schrieb:
Cup hinges, 35 mm (1.4 inches)
Soft-close optional
Pay close attention to the exact drilling dimensionsThese are great tips, especially the point about the precise drilling distance, which I find extremely important.
I once tried using alternative hinges because I was a bit experimental. After a while, I noticed that not every hinge type works reliably with Billy doors. The doors eventually warped or the fastenings loosened, which was quite frustrating.
So, my personal advice is to stick with the measurements and hinge types specified by the manufacturer. Putting in a bit more effort during installation is worth it to avoid having to fix things every year.
It also helps to adjust the hinges several times during installation if the shelf stands against a wall or on an uneven floor – this compensates for later stresses.
And last but not least: if you want a softer closing mechanism, there are retrofit kits for soft-close that can be easily added to standard hinges.
Good luck – that will definitely make your Billy look great!
