ᐅ What helps to stop squeaky hinges on Billy cabinet doors?
Created on: 13 Apr 2024 09:27
kieran48
Hello everyone, I have noticed annoying squeaking at the hinges of the doors on my Billy bookshelf. Despite careful use, the noise is quite bothersome. My specific question is: What reliably helps against squeaky hinges on Billy doors without having to completely remove or replace the hinges? Are there proven solutions to quickly and permanently fix this problem? I would also appreciate recommendations for suitable lubricants or methods.
blapau
14 Apr 2024 09:05
One more detail: With butt hinges, access is somewhat limited. You can easily remove the door to get better access to the hinges. This allows for the lubricant to be applied more precisely and effectively. If the squeaking is caused by light rust, it is advisable to gently clean the area first using fine sandpaper or steel wool.
GALENKU
14 Apr 2024 10:21
WD-40 as a multi-purpose lubricant is fine and usually works for me. Sometimes, simply opening and closing the door a few times firmly does the trick until the noise disappears.
lisku
14 Apr 2024 11:45
Paxton38 schrieb:
WD-40 is good for cleaning, but not very suitable as a long-term lubricant.
Exactly. WD-40 does dissolve residue but doesn’t provide lasting lubrication. Use a proper lubricant afterward.
Jukin
15 Apr 2024 07:17
Hello, I would like to elaborate on this topic a bit: Squeaking usually occurs when metal rubs against metal, and the risk is certainly higher with Billy doors due to their simple hinges. The best approach is to clean the hinges with a lint-free cloth, possibly slightly dampened, to remove dust and old lubricant residues. Afterwards, a high-quality lubricant specially designed for metal joints should be applied. Silicone sprays or graphite powder are recommended because they are not sticky and do not attract dust. WD-40 can provide a temporary fix but should not be used as a long-term solution. It is important to apply the lubricant sparingly and precisely. Good luck with it! 🙂
loken
15 Apr 2024 10:04
Jukin schrieb:
The best method is to clean the hinges with a lint-free cloth, possibly slightly dampened, to remove dust and old lubricant residues.
Works perfectly! Then a bit of care (and the right lubricant) will stop the doors from squeaking. Sometimes a gentle realignment of the door leaf helps if the hinge is slightly misaligned.
andre3
15 Apr 2024 11:27
loken schrieb:
Sometimes gently adjusting the door panel can help if the hinge is slightly misaligned.
That is correct, as lateral misalignments often cause mechanical noises. For a precise adjustment, use an Allen key to fine-tune the hinges and better align the door. This reduces stress and prevents squeaking.
