Hello everyone, I am planning to upgrade my Ikea Platsa cabinets with new handles and am currently a bit unsure about the options. Since the PLATSA series features a modular and flexible system with different fronts and sizes, it’s not entirely clear to me which types of handles work best here—both in terms of appearance and practicality. It is also important to me that the handles are easy to install and ideally match the existing drill holes on the PLATSA doors, so I don’t have to do much redrilling.
Has anyone had experience with specific handles for PLATSA and can offer recommendations? Which materials, shapes, or designs suit the modern but simple look particularly well? Are there any technical details regarding installation or handle alignment that should definitely be considered? Thanks for sharing your advice!
In addition to the previous information: Ikea Platsa handle holes are standardized with a 128 mm (5 inch) spacing. Most commercial cabinet handles therefore fit. The maximum thickness of the front panel is about 15 mm (0.6 inch), which limits the choice of screws.
Factors I consider when selecting handles:
- Material quality (rust-resistant, durable)
- Ergonomics
- Surface finish (matte vs. glossy)
Handles requiring excessively long screws or unusual fastenings should be avoided, as PLATSA does not tolerate additional drilling without damage.
Conclusion: Standard cabinet bar handles with 128 mm (5 inch) hole spacing, matte stainless steel, are technically the best choice.
- Ergonomics
I completely understand the uncertainties – handles make a big difference and should last a long time while looking good. In my experience, black metal handles have proven to be reliable and complement the simple design of PLATSA nicely. Installation was straightforward since I could use the existing holes.
Something else that reassured me: some handles allow you to easily adjust the screw length, which helps avoid issues. Maybe this will be useful for you when making your choice as well.
warrenka575 Nov 2024 12:45[@Palenar, post: g1o2p2, member: XXX]
"My question for you is: What types of fronts exactly are you using (solid doors, drawer fronts, glass fronts), and how large are the cabinets?"
I think these questions are really crucial to provide meaningful recommendations. In my case, only solid doors were used, where the 128mm (5 inches) hole spacing proved to be the perfect reference. Drawers with handle strips or recessed handles are a different matter altogether.
[@koduga, post:9, member: XXX]
"Some handles allow you to easily adjust the screw length."
That’s a tip I’m always happy to share! Sets often include screws of various lengths – it makes life much easier.
flo-Theres5 Nov 2024 13:17One more thought regarding the screws: Ikea often offers assembly kits with different lengths because the front panel thicknesses can vary depending on the PLATSA model. This means you don’t necessarily have to order new screws when buying handles if the original screws fit.
Additionally, the screw material should be rust-resistant, especially if the furniture is placed near the kitchen or bathroom, to prevent corrosion.
Since I was thinking about this again yesterday: Does anyone have experience with adding extra handles made from wooden strips or custom solutions for PLATSA?
From a technical perspective, I see two challenges here:
- The drilling accuracy
- The stability of the attachment due to the relatively thin front panel
If you want to install your own wooden handles, I would recommend reinforcing the back side or at least using dowels inserted into the back of the fronts.
I’m curious to hear if anyone has already gathered experience with this, so that maybe a guide or some tips can be shared.
Good point, Palenar. Handmade wooden handles can be visually appealing, but as you described, they do come with certain risks.
For those who still want to give it a try, here is a brief guide:
- Use narrow strips of wood that align precisely with the drill holes
- Use screws with a large bearing surface on the inside to distribute pressure on the front panel
- Pre-drilling is essential to prevent the wood from splitting
- Consider adding backing plates made of wood glue or thin MDF boards on the inside for extra stability
Although this requires more effort, it can create a very unique look.
