ᐅ Which DIY extensions are compatible with the Ikea Pax wardrobe?
Created on: 19 Mar 2024 08:12
getamiHello everyone, I am considering enhancing my Ikea Pax wardrobe with some DIY additions. What types of DIY extensions are particularly recommended here to maximize storage space and also meet individual needs? I am thinking of custom-made organizers, shelves, or perhaps lighting solutions. It is also important to me that the additions can be easily integrated into the system without compromising the structure or making assembly complicated. Does anyone have practical experience or tips on which DIY modifications work best and what to watch out for? Thanks in advance!
For the PAX wardrobe, custom-made shelves from wood or plexiglass fit best. You can easily attach them to the existing holes. LED strips can also be easily installed with adhesive tape and improve visibility. Important: pay attention to the weight so the side panels are not overloaded.
To optimize the Ikea PAX wardrobe, customized shelves and flexible dividers are recommended. Due to the material properties, MDF or plywood panels are suitable, which can be precisely cut to size. Another popular DIY option is pull-out baskets or boxes, which allow for dynamic use of storage space. For lighting, I suggest dimmable LED lights with low power consumption that can be powered via USB power banks to minimize installation effort. Important: Ensure that all modifications are reversible so the wardrobe can be returned to its standard configuration if needed.
I am really impressed by the DIY extensions for the PAX!!! Especially custom-built shoe racks or small hook strips for accessories fit perfectly, making the usage very versatile. Adding your own LED lighting with color-changing options also looks great and creates a nice atmosphere in the room. It’s definitely worth being creative to turn the wardrobe into a personal highlight!
There are several ways to customize the PAX wardrobe: You can easily make your own shelves from painted wooden boards that fit into the standardized drilled holes. Installing pull-out drawers or baskets can also make the storage space much more flexible. For those who frequently store clothing, consider adding hanging rods with integrated hooks to organize scarves or ties. For lighting, self-adhesive LED strips work well and can be installed at the top inside the wardrobe; it is important to ensure that the wiring is covered. It is best to carefully measure the width and depth of the interior space beforehand and cut the materials accordingly.
I would like to briefly summarize the best approach for DIY extensions for the Ikea PAX system:
- First, carefully consider the type of storage you need (e.g., hanging, stackable, open).
- For shelves, it’s best to use load-bearing MDF boards, which you can either paint or cover with veneer.
- Custom-built drawers on rollers can also be installed if you have precise measuring skills.
- For lighting installations, LED strips with low heat output are recommended.
- Make sure that all fittings are attached to the standard holes designed for the PAX system to avoid drilling new holes—this protects the material and the rubber seals of the doors.
If you want, I can also provide more detailed information on cutting or the materials used.
