I am currently working on my IKEA Besta combination and have noticed that the screws connecting the individual parts often remain visible. I am wondering: which covers work best for IKEA Besta screws?
I am mainly looking for a neat and aesthetically pleasing solution that is easy to install and matches well in color with the furniture. Are there specific covers from IKEA for the typical Besta screws, or are third-party accessories better suited?
It is also important for me that the covers are easy to handle during assembly and do not fall off later.
Does anyone have experience or specific tips regarding compatible covers that work best with the combination of material and screw types used (mostly cylinder head screws and cam locks)?
For the screws on IKEA Besta, I usually use the original IKEA covers, which come in white or black to match the furniture. These are specifically designed for the cam locks and fit very well.
Alternatively, simple plastic caps from the hardware store can also be used, but they often don’t look as good.
I can provide a brief guide on covers for IKEA Besta screws:
- Original IKEA cover caps: These are specifically designed for cam screws and cylinder head screws. They are usually available in white, black, or transparent, which matches well with the Besta finishes. Most importantly, they fit precisely and therefore do not come loose easily.
- Material and installation: The original covers are made of flexible plastic that creates a secure connection when pressed onto the screw. This prevents the caps from loosening or falling off.
- Alternatives from hardware stores: While there are various universal cover caps available, it is important to accurately measure the screw diameter (usually 15 to 20 cm (6 to 8 inches) for Besta). These standard caps are cheaper but do not always match perfectly in color or surface texture.
- Tips:
- Clean the surface lightly before installation to help the caps adhere better.
- Pay attention to the clip mount when purchasing; otherwise, the cover will not sit firmly.
Conclusion: For a neat, invisible, and durable solution, it is strongly recommended to use IKEA original parts. Although they usually cost a bit more, they save hassle during installation and use.
- Tips:
KUDAISY schrieb:
Conclusion: If you are looking for a clean, invisible, and durable solution, you should definitely use IKEA original parts.I agree, but I would like to add that using the original covers is also advisable because IKEA’s screws and cover systems are designed to work together.
- Not every universal cover cap type will hold up well under long-term heavy use, especially if you frequently move or modify the Besta shelves.
- Even if you use the correct measurements, the fit can vary by about a millimeter, which can cause loose fittings or unsightly gaps.
- Many third-party manufacturers also cut corners on material quality, which can lead to yellowing or cracking, especially with white plastic.
It would be interesting to hear if anyone has experience with IKEA replacement parts: Are the original covers available as spare parts directly from IKEA or third-party sellers? Has anyone used warranty services because the covers no longer fit or became brittle? I haven’t come across such practical experiences so far.
My advice: When it comes to appearance and durability, use the original parts and invest a bit more.
