ᐅ Which BILLY models are more durable than others?
Created on: 1 Nov 2021 08:42
Glaeshan
Glaeshan
1 Nov 2021 08:42
I have a specific question regarding the durability of IKEA Billy bookcases, as I am considering purchasing one for long-term use. There are now several different Billy models and variations, ranging from simple standard versions to smaller and wider designs with different material thicknesses and finishes.
I am particularly interested in whether there are objective differences in the durability of the various Billy models that become noticeable with daily use. Specifically: Which Billy models are more durable than others and why? For example, are the thicker shelves or additional back panels on some models noticeably more robust? How do the workmanship and materials hold up when using the models for many years, such as under frequent loading or rearranging?
I would greatly appreciate any experience reports or expert knowledge regarding these differences! Thank you in advance.
Palenar
1 Nov 2021 09:57
Hello Glaeshan,
very interesting question! Basically, the BILLY models do differ in several aspects that affect their durability. The standard 40 cm (16 inch) wide version uses particle boards about 16 mm (5/8 inch) thick, which is sufficient for normal use. The sturdier models, such as the wider ones or those with additional middle shelves, sometimes use 19 mm (3/4 inch) thick panels.
This results in significantly higher load capacity and torsional stiffness, which is especially important for heavier loads and long-term use. The back panels also vary – the thinner models often have simple chipboard, while higher-quality versions use MDF panels, which are much less prone to warping or breaking.
It’s also interesting that the gluing and edge banding on the more expensive BILLY versions are more precisely done, offering somewhat better protection against moisture. If you plan to store many or heavy books, or if you intend to place the shelf against a wall and rearrange it frequently, in my view the extra cost for thicker boards and better back panels is worth it.
However, when it comes to complete refurbishment or heavy use over several years, surface treatment and proper assembly make a huge difference. How exactly do you envision using the shelf? Are you asking about a shelf for your home or for a work environment?
boelnu
1 Nov 2021 10:26
Palenar schrieb:
If you plan to store many or heavy books, or if you intend to place the shelf against a wall and rearrange it frequently, in my opinion, the extra cost for thicker boards is worth it.
I can confirm this from my own experience. I initially bought the cheaper BILLY version, which after a few years of regular use developed cracks at the bottom rail because the shelf gave way too much under load without wall mounting. Honestly, I was surprised at how quickly it happened.
When I repurchased, I went for the thicker version with stronger back panels and thicker material – and the shelf has now lasted over 7 years without visible damage. For me, it was worth the extra money because you don’t want to keep buying new furniture just because the parts start to show wear after only a few years.
Especially for people who often experience that the load capacity is overestimated with BILLY, I can only recommend paying attention to sturdier versions from the start.
I’m also curious if there are differences in surface finishes: Does anyone know if there is a difference regarding scratch or moisture resistance?
GALEO4
1 Nov 2021 11:05
One could almost say that IKEA’s BILLY line focuses more on quantity than quality when it comes to durability. Of course, for the price, the shelf is unbeatable, but anyone looking for furniture that will reliably last a decade of everyday use should look elsewhere.
boelnu schrieb:
Especially for people who often find that BILLY’s load capacity is overestimated
Exactly! Many overestimate what this shelf can handle. A piece of furniture made from particleboard, where the back panel often serves merely as a stabilizer, is simply not designed for heavy loads.
The thickest model might be more stable, but in the long run, the core materials don’t change much. I see BILLY more as a short- to medium-term solution for those wanting an inexpensive shelf, rather than as durable furniture.
Are truly different materials involved, such as solid wood or veneered options? I doubt it. In my opinion, anyone expecting durability is mistaken.
fikeo
1 Nov 2021 12:14
GALEO4 schrieb:
I see BILLY more as a short- to medium-term solution for people who want an inexpensive shelf rather than a durable piece of furniture.
That’s a valid point, but the conditions of use should not be underestimated. When a BILLY shelf is used for the right purpose and properly maintained, it can be more durable than often assumed.
For example, the versions with extra sturdy shelves and back panels are capable of supporting heavy loads for many years. Additionally, the assembly with corner connectors and wall fixings can be made very robust, which significantly extends the lifespan.
However, anyone who frequently moves the shelf, overloads it improperly, or exposes the furniture to additional moisture will encounter problems even with the highest-quality version.
From my experience: careful assembly, reasonable loading, and occasionally tightening the screws make the difference. The standard BILLY units are intended more for light use, while the thicker or modified models hold up well in households with heavier use.
In conclusion: BILLY offers an affordable entry into durable furniture if the technical limits are respected.
Palenar
2 Nov 2021 07:51
GALEO4 schrieb:
The thicker model might be more stable, but in the long run, there is little change in the base materials.
I would somewhat disagree here, because at IKEA, the basic quality of the particle boards used in BILLY has indeed improved slightly over the years. Comparing models from the early 2000s with current ones, there are differences in the gluing and compaction of the particle boards, resulting in better moisture resistance and strength.
fikeo schrieb:
Careful assembly, reasonable loading, and occasionally tightening the screws make the difference.
I agree with that as well. The construction is basically simple, but that also makes it vulnerable to poor assembly or incorrect use. One thing I would still like to know: how about the cheaper BILLY versions that use only 12 millimeters (0.5 inches) thick shelves? Does anyone have long-term experience with those? Are they purely for decoration, or can they also support heavier loads?
