ᐅ Which assembly screws does IKEA use for PLATSA?
Created on: 3 Apr 2016 10:07
Janoschle
Janoschle
3 Apr 2016 10:07
I am currently planning the assembly of my new IKEA PLATSA cabinet system and wanted to ask which specific assembly screws IKEA uses for PLATSA. I have found various information online referring to different types and lengths of screws – ranging from wood screws to particleboard screws and even special partially threaded screws.
This is especially important for me because I need possible replacement parts and want to ensure that the screws are strong enough to securely fix the construction. Is there an official specification for this, or can you roughly tell me which types and sizes of screws IKEA uses for PLATSA? I would be very grateful for any helpful details or explanations!
Merlin
3 Apr 2016 10:53
IKEA PLATSA mainly uses particle board screws with a diameter of 4 mm (0.16 inches) and partial threading, usually 35 to 45 mm (1.4 to 1.8 inches) long.
Wood screws are rarely used, since the modules are made from panels.
TARNE
3 Apr 2016 11:26
Really interesting that you bring this up! 😃 The issue with the screws is actually a bit more complex than it seems!
I’ve assembled several PLATSA modules myself and can confirm that IKEA consistently uses chipboard screws with partial threads, which provide strong hold and screw into the material well. So if you need replacements, make sure to use the thicker type, otherwise you might quickly run into stability problems! Good luck with the assembly!
Sinan-meo
3 Apr 2016 12:17
The question about the type of screws is a bit more complex, as IKEA actually uses different types of screws depending on the part. Essentially, the basic assembly involves chipboard screws with partial threads, often in lengths of 35 mm (1.4 inches). For connections with metal fittings such as brackets or hinges, cross-head wood screws are typically used, usually 4x16 mm (0.16x0.63 inches).
I recommend checking with the official IKEA customer service for replacement parts, as the screws are specifically matched for the modular construction system.
Janoschle
4 Apr 2016 08:45
Sinan-meo schrieb:
Basically, the basic assembly involves chipboard screws with partial threading, often with lengths of 35 mm (1.4 inches).
Thanks, that helps me a lot. Do you happen to know whether these screws are galvanized or stainless steel? I would like to understand how the screws react to moisture or during adjustments in use. This is particularly relevant for the PLATSA cabinets, which can be placed in humid rooms.
WARREN
4 Apr 2016 09:12
The screws are galvanized to protect against rust. Stainless steel is rarely used in IKEA PLATSA, mostly only for specific fittings.
