ᐅ What types of screws does Ikea Hemnes use?
Created on: 26 Aug 2021 14:37
glalau
glalau
26 Aug 2021 14:37
Hello everyone, I recently purchased the IKEA Hemnes bedroom furniture set and noticed during assembly that different types of screws are used. Since I don’t have the exact names and specifications of the screws, I would like to ask specifically: Which types of screws are used in IKEA Hemnes furniture? I’m interested both in the kinds of screws (e.g., wood screws, cam locks, machine screws) and details like dimensions and materials, if anyone can provide that information. This will help me not only for possible reorders but also if I ever need replacements or better alternatives. Thanks in advance for all your answers – I’m curious to learn how varied the screw selection actually is and what experiences you have had with them!
Ramon4
26 Aug 2021 15:12
Hello glalau, your question is very precise, I like that! For Hemnes furniture, IKEA typically uses a combination of several types of screws designed to ensure stability and easy assembly. These usually include: - 6 mm (1/4 inch) wood screws (mostly galvanized) used for joining the wood panels - Cam lock screws with corresponding dowels, which pull two boards tightly together - Machine screws with hex key heads, especially for drawer runners - Smaller particleboard screws for connection points In addition, metal connectors or brackets are often used as reinforcements, secured with additional machine screws. The sizes vary, approximately from 4x30 mm (5/16x1 1/4 inches) to 6x50 mm (1/4x2 inches), depending on the location. If you want to identify the original screws more precisely, checking the assembly manual usually helps a lot – it typically lists all screws including their dimensions. Hope this helps you already! If you need replacements, you can opt for galvanized or stainless steel screws of comparable sizes to avoid rust.
Kinbu
26 Aug 2021 15:47
In addition to Ramon’s excellent answer, I would like to add that IKEA mainly uses special connectors for Hemnes furniture that are not traditional screws, such as cam lock fittings (also called cam connectors). These consist of two parts: a bolt that is inserted into a hole and a matching cam that tightens the bolt. This is a standard technique at IKEA and provides strong stability while keeping screw heads less visible. The screws themselves are usually zinc-plated or made of steel with a corrosion-resistant coating. For the visible parts that are often screwed, IKEA frequently uses screws with hex socket heads that can be easily tightened with the supplied Allen key. Smaller connections use chipboard screws that grip into MDF or wood-based panels. Dimensions and exact types can vary slightly depending on the piece of furniture. Therefore, it is worth studying the assembly instructions carefully, as the screws are often labeled with letters or numbers there.
Khalil
26 Aug 2021 16:23
Hey everyone! I totally agree with glalau, that’s a really good question because I’ve had to replace these screws a few times myself! 😄 For Hemnes, I usually use the classic IKEA cam lock fasteners – super sturdy and easy to install! What I especially like is the combination of the cam lock and the matching dowel, which holds the wood very securely together. Also, the wood screws are often quite long, around 50mm (2 inches), to make the connection really strong. Most screws have a hex key (Allen) head, which is very practical. If anyone ever needs replacements: I’d recommend using good quality, galvanized screws, since they last much longer. Looking forward to seeing more tips and details here, great topic!!! 😉🔥
theo63
27 Aug 2021 09:04
I find it interesting to take a closer look at the specifications here. It is often said that IKEA uses standard fastening techniques, but how high-quality are these screws actually? The stability of Hemnes furniture is frequently praised, yet screws of varying quality could affect both durability and load-bearing capacity. An important factor is the choice of material. Galvanized steel screws are common but can rust if the furniture is exposed to moisture. Stainless steel would be better here but is rarely used due to higher cost. The type of thread also matters: coarse threads are suitable for wood-based materials, while fine threads are preferred for metal or machine parts. The clamping force created by cam screws is cleverly designed, but the quality of the fastener and its resistance to loosening are critical. This is something worth considering more closely when planning replacements.
TAUPLO
27 Aug 2021 11:15
theo63 schrieb:
Galvanized steel screws are widely used but can rust if the furniture is exposed to moisture.
Absolutely, you’ve raised an important point. 🙂 I would add that IKEA’s Hemnes line probably strikes a good balance between quality and price. The screws are sturdy enough for everyday use, and the Allen key makes assembly quite comfortable even for less experienced DIYers. If you see it as a DIY project, it’s a solid foundation. Certainly not premium wooden furniture with stainless steel screws, but for the price and stability, it’s really impressive. Personally, I find the mix of cam lock fasteners, wood screws, and machine screws quite clever – it allows for quick and efficient assembly. 😄
