ᐅ What alternatives to standard fronts are suitable for IKEA BESTA?
Created on: 8 Feb 2019 14:23
Gu_noemiHello everyone,
I am currently exploring ways to customize IKEA Besta systems to make them more visually appealing and unique, without using the typical standard fronts, which often look quite plain and generic. Therefore, my question is: What alternatives to the standard fronts work well with the Besta system in terms of installation, design, and quality? I am especially interested in options suitable for retrofitting or replacement fronts that are not only functional but also add a personal touch to the furniture. Has anyone had experience with alternative manufacturers, DIY fronts, or creative solutions such as vinyl wraps, laser-cut designs, or other materials? Any advice on installation and durability would also be greatly appreciated.
Gu_noemi schrieb:
What alternatives to the standard fronts work well for the BESTA system, both in terms of installation and design and quality?A truly interesting question that shows how much we tend to stick to existing furniture styles instead of getting really creative. I think most people too quickly choose ready-made fronts from accessory suppliers or simply accept the IKEA fronts as they are. Why not try customizing yourself?
- Why not have fronts cut from plywood or MDF, then sanded, primed, and either painted or covered with veneer or foil?
- Or why not recycle old furniture and reuse their doors?
I believe the BESTA system is especially suitable for this because it is modular and the doors can be replaced relatively easily. Of course, the effort is higher, but so is the visual reward.
Regarding installation: IKEA provides specific hinges and mounting hardware for this, but it doesn't always fit perfectly. Anyone who plans carefully and maybe customizes a bit will already be ahead.
Last but not least: quality also depends on the materials used. If working with laminate foil or plastic, attention must be paid to craftsmanship. Real wood naturally looks better, but it is also more expensive.
In summary: The possibilities are many – it is worth investing some time to create something truly unique.
Quick tips:
- Have wooden doors cut to size (MDF or solid wood)
- Alternative self-adhesive foil surfaces
- IKEA-compatible replacement fronts, e.g., from third-party suppliers
- Paint or stain yourself
Usually fits easily if you take measurements and know the standard drilling points.
Gilbert schrieb:
I think the BESTA system is particularly suitable because it is modular and the doors can be changed relatively easily.That’s true, Gilbert. BESTA is indeed very flexible due to its modular design, which also makes replacing the fronts easier. I’d like to add the following:
For those with DIY experience, these alternatives are worth considering:
- Custom-made wooden fronts using MDF or plywood, which can be easily painted or veneered. It’s important to pay attention to thickness, so the door’s weight is not too heavy for the hinges.
- Fronts made of acrylic glass or even thin metal for a modern look. Proper mounting is essential here, usually with special hinges.
- Ready-made replacement fronts from smaller manufacturers specializing in IKEA systems. These come in many designs, from matte to glossy finishes, as well as wood appearances.
- Self-adhesive films offer a quick and affordable solution but are more suitable for lighter applications or surface changes rather than fronts that are frequently moved.
With all these options, precise measurements and attention to mounting points are crucial to ensure smooth replacement and stable fitting of the fronts.
I’d also recommend replacing the hinges with higher-quality ones if necessary, to ensure better durability.
If you need advice on specific tools or craftsmanship, I’m happy to help.
Good luck with your project!
