ᐅ What tips are there for perfectly aligning Ikea Metod cabinet doors?
Created on: 4 Jan 2019 08:13
mineoklis
I recently assembled an Ikea Metod kitchen cabinet and now face the challenge of aligning the cabinet doors precisely. There are often small misalignments, door edges are not completely flush, or the doors don’t close evenly—especially when several doors are side by side. Are there any proven tips or reliable methods to position the doors as accurately and permanently as possible? I am particularly interested in mechanical adjustment options on the IKEA Metod hinge fittings, tools to assist with alignment, or specific steps that make the process easier. I want very small gaps and uniform spacing, which is possible with the Metod series thanks to its modular design but not straightforward. Thanks for your advice!
praWarre69
5 Jan 2019 17:23
Hello! Here’s a practical tip: If you want to keep the gap between your Metod doors really minimal when aligning them, a bit of finesse with a thin ruler or a piece of paper can help. Place the ruler as a measuring guide along the door gap to check if the space is evenly wide all around.
Sure, it sounds simple, but sometimes you only notice a slight imbalance when comparing both sides directly. And if the gap is a bit wider in one spot, you can precisely adjust it using the side adjustment screw.
It’s fun once you get the hang of it – with Metod hinges, you can really fine-tune the alignment well. Good luck and don’t lose heart! 😉
Katau
6 Jan 2019 10:11
A complete workflow for perfect alignment could look like this:
- First, align the cabinet precisely horizontally and mount it securely.
- Then roughly hang all the doors and use the height adjustment screws to bring them to the same top edge.
- Next, adjust the gap widths between the doors and the cabinet body using the side screws.
- Carefully set the depth adjustment to ensure the door closes properly and to fine-tune the distance to the cabinet body.
It is important to open and close the door several times after each screw adjustment and visually check the alignment. If there are multiple doors, it makes sense to start with the doors that will serve as a reference and then adjust the adjacent doors accordingly.
This way, you achieve a harmonious overall appearance. Also, pay attention to wear or bent components.
V
vinpau
6 Jan 2019 12:44
Exactly! That’s the perfect approach, well summarized!
I’ll add this: It’s easier with a second person helping – while one holds the door, the other adjusts the screws. And very important: if something gets stuck, never use force; instead, make small adjustments and always check. That way, achieving the perfect result is guaranteed! 🚀
