ᐅ What should you do if connector pieces break on Billy shelves?
Created on: 9 Jan 2017 08:12
moson
moson
9 Jan 2017 08:12
I recently assembled a Billy shelf from IKEA, and after some time, I have been experiencing issues with the connecting fittings. They seem to break very easily, which quickly reduces the stability of the shelf.
I’m interested in knowing: What can be done if the connecting fittings on Billy shelves break? Are there ways to repair, replace, or even use better alternatives that last longer?
I’ve heard that some people replace the fittings with different materials or reinforce them somehow. What are your experiences or recommendations? Thanks in advance!
Renegi
9 Jan 2017 08:34
If the connectors break, I would simply buy new ones from IKEA. Often, spare parts can also be ordered. Alternatively, stronger screws and small metal brackets can help to reinforce the shelf.
jordanvin
9 Jan 2017 09:01
That’s great that you brought up this topic! 🙂 I had the same issue once and just bought a few stronger connectors from a hardware store. Since then, the shelf has been holding up perfectly, and I’m really happy! Sometimes you just have to be creative and try new solutions. Keep it up!
moson
9 Jan 2017 10:23
Renegi schrieb:
Alternatively, stronger screws and small metal brackets can help to secure the shelf additionally.
Thanks for the tip! Could you please specify which screws you mean? Are there particular types that have proven especially effective? The metal brackets also sound interesting, but should I install them in specific locations?
Tarmau
9 Jan 2017 11:15
Regarding the question about replacements: Billy shelves often use so-called dowel or Minifix connectors made of plastic, which can break depending on the load.
A practical solution is to replace the original connectors with metal fittings, which are available from specialist suppliers. These provide significantly higher stability and durability.
When attaching the metal brackets, it is advisable to fix them at the bottom and top of the shelf sides to prevent tipping. Screws should preferably be zinc-plated and have a diameter of 3-4 mm (0.12-0.16 inches), depending on the material of the shelf panels.
Pre-drilling the holes is also recommended to protect the material and prevent splitting.
kaju67
9 Jan 2017 12:42
moson schrieb:
Can you be more specific about which screws you mean? Are there particular types that have proven especially reliable?
I’ve used standard wood screws (4x40mm (5/32 x 1 1/2 inches)) before, and they work quite well. Always tighten them carefully and use metal brackets if possible; this way, the Billy becomes really sturdy and stable 🙂 Not only is it strong, but it also looks good!
