ᐅ What to do if your Ikea Metod cabinet doors are loose?
Created on: 10 Apr 2020 08:37
Fuonpe
Fuonpe
10 Apr 2020 08:37
I have been experiencing an issue with my IKEA Metod cabinet fronts for some time now. Some of the fronts no longer sit firmly on the hinges and are noticeably loose, which can be annoying when opening and closing. This is especially noticeable on cabinets that are used more frequently. The fronts do not appear damaged or warped; it seems to be related more to the mounting or the dowels/hinge adjustments.
Does anyone know this problem and have tips on how to properly secure these loose fronts again? Are there any specific tricks or tools to readjust the screws or hinges? Any advice on whether this issue is normal wear and tear or possibly due to incorrect installation would also be very helpful.
Thanks in advance for your support!
Rashadmeo
10 Apr 2020 09:14
Hey Fuonpe, that sounds annoying, but don’t worry, we can fix it! 😊
With Metod systems, it’s common for the screws on the hinges to loosen a bit over time due to frequent opening and closing. The trick is to simply tighten all the hinges carefully once. Usually, that’s enough to get the cabinet fronts back firmly and evenly in place.
If you don’t have the right screwdrivers: IKEA often uses Phillips (PH2) for the hinges.
And hey, if you want to realign the fronts afterward, there are small adjustment screws on the hinges that let you fine-tune the door horizontally, vertically, and in depth. That way, they’ll sit perfectly straight again. You’ve got this! 👍
rubybi
10 Apr 2020 09:45
Hello Fuonpe,
I’m happy to give you a detailed guide on how to reattach your Metod cabinet fronts securely. I have several types of IKEA cabinets myself and am familiar with this issue.
1. Check the screws:
- Open the door fully.
- Tighten each screw on the hinge using a suitable Phillips (+) screwdriver.
- Make sure the screws inside the wooden cabinet carcass are also tight.
2. Adjust the hinges:
- Each Metod hinge usually has three adjustment screws.
- The horizontal screw lets you move the door left or right.
- The vertical screw is used to raise or lower the front.
- The depth adjustment controls how closely the door sits against the carcass.
3. Inspect the fixing points:
- Sometimes the dowels loosen, or the drilled holes become slightly enlarged due to constant pressure.
- If the screws still feel loose after tightening, a small wooden wedge or dowel can help stabilize the hole.
Tip: Don’t use screws that are too long, as excessive pressure can warp the front.
In summary: Tight screws + fine adjustment via the adjustment screws + check the fixing points = a stable front.
If you want, I can also share tips on how to properly align the doors for a perfect visual fit.
draleo
10 Apr 2020 10:23
Additional information: For loose cabinet doors on IKEA Metod furniture, tightening the hinge screws is the first and most important step. Often, the cause is that the screws have loosened due to stress and movement.
- Use an appropriate Phillips screwdriver (PH2) for optimal torque transfer.
- Check all screws on the hinge and the mounting bracket inside the cabinet.
- If the drill holes are worn out, you can stabilize the holes again using wooden dowels or small wood pieces.
- It may also help to adjust the metal hinge mechanisms to align and secure the doors.
Important: In cases of severe wear in the holes, using wooden dowels or re-drilling with a filling technique is recommended to restore long-term functionality.
Katan
10 Apr 2020 11:02
rubybi schrieb:
The depth controls how close the door sits to the cabinet frame.
This is often the tricky part for me. If the door doesn’t sit flush, it feels loose even though all the screws are fine.
What I personally like to do: after tightening the screws, experiment a bit with the adjustment screws – sometimes a small change in depth is enough to stop the rattling.
A little tip from me: once the screws are really tight, try opening and closing the door several times in stages. That can help “bed in” the mechanism again.
And keep at it, it’s really not rocket science! 😎
JORDON
10 Apr 2020 12:35
Hey Fuonpe,
loosely fitting IKEA Metod cabinet fronts can also be caused by lack of maintenance on the doors. If dirt or dust accumulates in the fittings, the adjustment screws no longer work as precisely as intended.
My suggestion:
- Thoroughly clean the fronts and hinges, preferably with a soft, damp cloth and mild dish soap.
- Then lightly lubricate all moving parts with silicone spray or another suitable lubricant. Avoid oils, as they attract dust.
This will not only restore a secure fit but also make the doors open and close more smoothly.
Give it a try—this is often overlooked but can work wonders! 😉
