ᐅ What are some useful tips for installing Ikea Besta units under sloped ceilings?
Created on: 4 May 2024 19:32
Marivory53
Marivory53
4 May 2024 19:32
I am planning to use Ikea Besta cabinet systems in my attic. The challenge is, of course, the pitched roof, which makes the installation more complex—especially regarding measurements, space utilization, and the stability of the cabinets in angled areas.
So, my specific question is: What tips and tricks do you have for precise fitting, assembly, and optimal use of Ikea Besta in combination with pitched roofs? I am particularly interested in experiences related to cutting, reinforcements, types of adjustments, and any useful additions to make the most of the storage space without compromising the appearance or functionality.
I look forward to practical recommendations, including pointers on what to watch out for to ensure the construction is safe and long-lasting.
Joshbe
5 May 2024 08:47
Hello Marivory53,
Here are some precise tips for using Ikea Besta units under sloped ceilings:
- Accuracy is essential: Measure the sloped wall or the angle of the ceiling precisely. Using angle measuring tools or apps with digital inclinometers is recommended to get exact values.
- Cutting modules: Ikea Besta units are standardized; for slopes, it is advisable to adjust the back panels or side panels with a saw accordingly. Work carefully to avoid compromising stability.
- Reinforcing the furniture: In the area of the sloped ceiling, it can be helpful to use additional corner brackets or sturdy wooden battens for support to prevent deformation.
- Using gaps: Between the sloped ceiling and the cabinet, you can install shelves or smaller storage surfaces to make optimal use of space.
It is important not only to cut the cabinets to size but also to check whether the weight is distributed correctly and the components can safely handle tension or compression loads. Another tip is not to place modules directly on the floor if there is no solid base against the sloped wall — in such cases, base plates or adjustable feet provide a solution.
These suggestions are based on several completed attic conversions using Ikea furniture. If you need more details on specific steps, feel free to ask.
Jensson
6 May 2024 11:09
Joshbe schrieb:
Dimensional accuracy is essential: Measure the slanted wall or the angle of the roof pitch precisely.
I would like to add to this and explain in more detail because many beginners tend to make avoidable mistakes in this area.
If you want to fit Ikea Besta units to pitched ceilings, I recommend the following procedure:
- Step 1: Determine the angle – Use a digital angle finder or an app that provides precise measurements of the roof pitch angle.
- Step 2: Verify measurements – Measure the height at several points along the slope as well as the length of each wall section to account for any irregularities. Measuring only one point is not sufficient.
- Step 3: Create a sketch – Draw the planned cabinet combination to scale, making sure the angles and dimensions are clearly visible.
- Step 4: Adjust the module fronts and back panels – Often, you will need to trim the backs, shelves, or side panels of the Besta units to fit the slope. A Japanese pull saw or a jigsaw with a fine blade guide works well for this.
- Step 5: Provide additional stability – For long rows of cabinets under the slope, I recommend using support strips or sturdy wood panels as a base structure. This prevents individual modules from warping or the slope putting pressure on the furniture.
In summary: Common sources of error are inaccurate measurements and lack of secure attachment of the furniture to the wall or floor. These steps will ensure your cabinets remain stable over time despite the demands of the sloped ceiling.
I can also provide a brief step-by-step guide on how to correct angle deviations if there is interest.
Joe52
7 May 2024 14:21
Marivory53 schrieb:
What tips and tricks do you have for precise fitting, installation, and optimal use of Ikea Besta units combined with sloped ceilings?
You’re asking a really interesting question that will definitely help many people here in the forum. From my own experience, the biggest challenge is the uncertainty when cutting and the fear that the furniture might become unstable.
One tip from me: Be patient when measuring – it’s better to double-check than to have to fix mistakes later. I was advised to first place the individual cabinet modules that need to fit under the slope loosely, and then proceed step by step with cutting.
Also, it helped me to finish any cut edges that might remain visible later with appropriate sandpaper and to touch them up with matching paint or stain. This greatly improves the appearance.
By the way, if you’re worried about weakening stability: There are special corner connectors for Besta that provide extra strength, especially in challenging conditions.
I hope this gives you some confidence to take on the project!
Maria35
7 May 2024 18:06
Jensson schrieb:
Sources of errors are inaccurate measurements and missing fixings of the furniture to the wall or floor.
I can only agree with that. From a technical point of view, it is absolutely necessary to always secure cabinets to the existing walls, especially in sloped ceiling areas.
Additionally, I recommend attaching load-bearing furniture parts from the Besta series with wall anchors. This increases safety and almost eliminates the risk of tipping.
If cutting the modules is necessary, care should be taken to use high-quality saw blades to avoid fraying, which can affect stability.
Finally, a practical tip regarding usability: when planning, make sure that drawers and doors can open easily even under the slope. It is advisable to position the cabinets so that at least part of the front is plumb.
Proper work preparation and good quality materials are therefore the key.
