ᐅ What tips are there for assembling IKEA Hemnes furniture smoothly as a beginner?
Created on: 26 Feb 2021 09:37
Gaufa
Gaufa
26 Feb 2021 09:37
Hello everyone, I’m planning to assemble the IKEA Hemnes wardrobe myself, but I’m a complete beginner when it comes to furniture assembly. My specific question is: What practical tips and methods can you recommend to make the assembly as smooth and efficient as possible? I’m especially interested in how to avoid common mistakes, which tools are essential, and whether it’s better to do the assembly with two people or if it can be done alone. I feel like the instructions can be somewhat complicated at times, so it would also be helpful to know the best way to follow them or if there are particular sections that require extra attention. Thanks in advance for your experiences and advice!
PECLARISSA
26 Feb 2021 10:52
Hey Gaufa, I know exactly how you feel! The Hemnes is a sturdy piece of furniture, but for a beginner, the first assembly can be a bit intimidating. My advice: take it easy and stay positive when putting together the cabinet! 😄
- Carefully open the packaging and sort all the parts so you don’t have to search or mix anything up.
- Having an extra pair of hands is invaluable, especially for lifting the heavy parts – it saves both nerves and time.
- Follow the instructions step by step and in order – don’t skip anything!
- For screwing, I recommend a cordless drill with adjustable torque to avoid over-tightening the screws (which can damage the material).
And most importantly: take breaks, nobody’s perfect right away. This way, everything stays relaxed, and in the end, the Hemnes will definitely be sturdy and looking great.
Parbo
26 Feb 2021 16:43
[a quote=PECLARISSA, post: d1p1p5, member: XXX]A small helper is worth gold, especially for lifting the heavy parts – it saves nerves and time.[/quote]
That is absolutely true. I would also recommend thoroughly checking the assembly parts and tools before starting the actual construction. Here is a more detailed checklist:
- Check all screws, wall anchors, and wooden parts for completeness – sometimes something is missing with IKEA, but you can usually respond quickly if you notice it right away.
- Sort the parts according to construction stages (e.g., parts for the carcass, doors, drawers) and label them with small notes if needed.
- For screwing tasks, it’s best to use a cordless drill with adjustable torque to control the screw-in process optimally. Having a matching Phillips screwdriver as a backup can be helpful in case the battery runs out.
- During assembly, it is important, especially when putting the drawers together, to pay close attention to the fit of the wooden parts – errors often happen here when working too fast.
- If possible, assemble on a soft surface (e.g., carpet or blanket) to avoid scratches on the furniture parts and the floor.
One more question for you: Do you prefer working alone, or can you arrange someone to assist? For some steps, such as hanging the doors, having a second person is quite useful. If you are alone, plan extra time for these tasks.
Do you already have tools at home, or would you like recommendations?
faso31
27 Feb 2021 08:29
Parbo schrieb:
Check all screws, anchors, and wooden parts for completeness
I fully agree, but I would also like to ask to what extent one should really trust the instructions. I often notice that many people follow IKEA furniture manuals strictly without thinking.
I believe it’s worth pausing briefly to mentally understand the logic of the construction steps. Only then can you avoid errors in the sequence that are difficult to fix later.
Often, I see screws being inserted too early or incorrectly, or parts being installed twisted, which affects stability. Therefore, I recommend:
- Read the entire instructions carefully before starting assembly.
- Be patient and if something is unclear, go back and review the previous steps.
- Only deviate from the instructions for a good reason—for example, if an alternative seems easier to you.
Also, feel free to post during assembly if you get stuck at any point. The community is happy to help with advice.
How far along are you with your preparations? Have you already measured parts or read through the entire instructions?
Danabla
27 Feb 2021 14:06
Additional notes:
- When assembling, make sure all screws are tightened firmly but not over-tightened. Over-tightening can damage the wood, especially with MDF parts.
- Use a spirit level or a smartphone leveling app to ensure the cabinet is properly aligned, especially at the base and on the shelves.
- For the Hemnes series, it is recommended not to attach the back panel too early to allow for easier adjustments and leveling.
- Pay attention to the installation of the baseboards and securing furniture screws to ensure stability.
The written instructions and included diagrams are detailed, but a structured and methodical assembly process is very helpful.
Could you also let me know if you have any difficulties with the assembly instructions in English or German? Some translated terms can be ambiguous and cause misunderstandings.
