I have several IKEA Hemnes shelves at home that I actually like a lot – but unfortunately, I noticed that some of them wobble quite a bit when I walk past or touch them lightly. This happens especially with the larger models, which so far are only secured to the wall with anchors.
I have tried checking the screws and tightening the wall brackets again, but the problem persists.
So my question is: What can I specifically do if IKEA Hemnes shelves wobble? Are there proven methods to significantly improve stability without completely taking them apart or hiring professional tradespeople?
I would like to know if the issue could be related to the wall mounting, or if it is more due to the construction itself. If anyone has experience with special tricks or additional reinforcements, I would appreciate any tips. Thanks!
I agree with the previous recommendations and would like to add a few additional thoughts:
It is important to understand the cause. With IKEA Hemnes shelves, the wobbling usually comes from one of the following:
- the wall mounting
- the floor surface
- or the connections between the individual parts of the shelf
Here is a simple step-by-step guide:
- Check if the screws are firmly seated in appropriate anchors and if the wall is suitable for these anchors (for example, drywall requires special hollow wall anchors).
- Make sure the floor under the shelf is level; small unevenness can be compensated with felt pads or furniture shims.
- Verify that the back panel (usually made of thin wood) is securely fixed and visibly attached, as it significantly increases stability.
- If there is play within the shelf itself, and you are handy, you can add small reinforcing strips or attach corner brackets from the inside.
You don’t need to be a professional, but a bit of care during assembly and, if necessary, optimization usually provides the desired stability.
I hope this helps!
- the wall mounting
- the floor surface
I hope this helps!
