ᐅ What panel thickness is recommended for preventing damage to the back panel in KALLAX units?
Created on: 17 Mar 2017 19:07
CarstenleC
Carstenle17 Mar 2017 19:07Hello everyone,
I am currently planning to set up an IKEA KALLAX shelf in my living room and am considering which panel thickness would be best for mounting to protect the shelf’s back panel.
Many users report that panels that are either too thick or too thin can cause the back panel to become damaged or unstable. Since the back panel is relatively thin and delicate, I want to avoid it warping or cracking under load or during transport.
I am especially interested in:
- What thickness or panel height do other users recommend for the back panel, particularly when assembling it yourself?
- Are there any experiences regarding which panel thicknesses are better suited to ensure stability and protect the material?
- Do most people use the standard IKEA panels, or do many opt for alternatives?
I look forward to your experiences and recommendations so I can find a suitable solution that is both functional and gentle on the back panel.
Carstenle
Carstenle
Carstenle schrieb:
What thickness or panel height do other users recommend for the back panel, especially for self-assembly?It’s great that you’re putting so much thought into the back panel! 🙂 From my experience, a panel thickness of about 3 mm (0.12 inches) works best for KALLAX.
Why? Because the back panel is then sturdy enough without being too thick, which also helps preserve the material. I once tried 5 mm (0.2 inches), and the back panel warped – so it’s better to keep it a bit thinner.
Carstenle schrieb:
Are there any practical experiences regarding which panel thickness is better suited to ensure stability and protect the material?Yes! Especially with thin back panels, proper stability is only achieved with the right thickness. I specifically chose MDF panels that were 3 mm (0.12 inches) thick, and it worked perfectly!
Don’t worry, you’ll manage it! 🙂
Hello Carstenle,
I’m replying in more detail because the topic of back panels for the KALLAX shelf unit is something that concerns many people.
Basically, the standard back panels for IKEA KALLAX shelves are quite thin, about 3 mm (0.1 inches), and made from relatively soft material (fiberboard). This means that thinner panels under 3 mm (0.1 inches) are usually not stable enough and can be easily damaged, while thicker panels (for example, 5 mm (0.2 inches) or more) are often too heavy and inflexible, which can make installation difficult and cause pressure marks.
Many people therefore use MDF panels with a thickness of around 3 mm (0.1 inches) up to a maximum of 4 mm (0.15 inches) to ensure sufficient stability without putting too much strain on the back panel.
Also, when fitting the back panel, make sure it isn’t clamped in too tightly. The correct panel thickness helps prevent tension that could otherwise lead to cracks or warping.
Furthermore, the ideal dimensions also depend on whether you plan to glue the back panel in place or not. If the panel will be glued, it’s advisable to leave a little extra allowance in the height.
If you like, I can provide exact measurements and tips for cutting.
Best regards!
Best regards!
Josan schrieb:
MDF panels with a thickness of around 3 mm (1/8 inch) up to a maximum of 4 mm (5/32 inch) to ensure secure stabilityThanks for the details, Josan, that really clears things up.
I remember feeling unsure when I assembled my KALLAX shelf. The back panel didn’t fit properly at first, and I was worried it might crack.
What helped me, besides choosing the right panel thickness, was being patient and carefully fitting the back panel without using too much force. I also applied a small amount of lubricant to the edges to make insertion easier.
Josan schrieb:
Also, when inserting the back panel, make sure it is not clamped in too tightly.That’s an important point I definitely want to emphasize. A back panel that’s clamped too tightly is effectively under constant stress and can crack or warp more quickly.
I completely understand how a DIYer can feel unsure in this situation, but with the correct panel thickness and careful installation, it’s definitely manageable.
Good luck to everyone who has yet to start their assembly! 🙂
