ᐅ What protective measures are recommended for IKEA Metod kitchen cabinets during a move?
Created on: 2 Sep 2023 09:23
Glapin
Glapin
2 Sep 2023 09:23
I am planning to move soon and have an IKEA Metod kitchen, which I want to transport with as little damage as possible. Since the Metod kitchen units are divided into modules and connected with panels, I am wondering: What specific protective measures are recommended to best protect the Metod kitchen furniture during the move?
I am interested in all the details: How should I pack the individual parts? Are there any special materials or methods that prevent damage to surfaces and connectors? Should I remove hinges or cabinet doors beforehand? Perhaps someone has experience with whether special padding or additional reinforcements are useful.
Beyond tips for proper disassembly and reassembly, I would also appreciate advice on how to best avoid damage to sensitive surfaces, such as foil fronts or glass.
Thanks in advance for your expertise!
RENMA
2 Sep 2023 10:08
To best protect the IKEA Metod kitchen furniture from damage during a move, I recommend a structured approach.
- Fully disassemble the furniture, especially removing countertops and all doors, to avoid stress points.
- Store fittings and screws in labeled containers or bags to simplify reassembly later.
- Use foam or bubble wrap for surfaces—particularly for foil-covered fronts and glass—to prevent scratches.
- Wrap edges and corners with thick edge protectors or foam padding.
- Store and transport large parts as flat as possible, avoiding placing them on their corners.
- Pack heavy accessories separately and securely.
This approach minimizes mechanical stress and protects delicate surfaces from abrasion and impact.
Kinbu
2 Sep 2023 12:17
RENMA schrieb:
For surfaces – especially foil fronts and glass – use foam or bubble wrap to prevent scratches.
This is definitely an important point. Additionally, I would recommend:
- Remove hinges and pack them separately and securely. This helps reduce possible misalignment and damage during transport.
- When packing large side panels or cabinets, use blankets or thick moving cloths to provide extra surface protection.
- Document the disassembly process step-by-step with photos to avoid mistakes during reassembly.
- Once the kitchen is completely dismantled, transport the parts lying flat to minimize stress on the cabinets.
The entire kitchen structure is quite sensitive to improper handling, so it’s worth being especially careful here.
juMira46
2 Sep 2023 15:42
Hello! In addition to the practical tips here, a quick reminder: When moving with IKEA Metod kitchen cabinets, it’s not only about avoiding damage but also about handling them in a way that saves your nerves 😅.
- When dismantling, it’s a good idea to have a friend or family member help out; working together is more enjoyable and less stressful.
- For packing, using inexpensive thick stretch film can help secure everything in place without slipping.
- If you remove doors, don’t forget to safely collect the handles and hinges in small bags.
- And don’t forget: after packing, clearly label all boxes and parts – this will save a lot of time and stress during reassembly.
However you choose to do it, don’t let the moving stress get to you; your kitchen will thank you!
geralu
3 Sep 2023 08:29
Please consider the following:
- Remove doors and drawers and secure them separately.
- Protect cabinets with ceilings or coverings against impacts.
- Label screws and small parts and store them in containers.
- Cover surfaces with foil or paper.
- Transport larger parts flat.
flo-Theres
3 Sep 2023 11:11
This is essential to prevent damage. Additionally, I recommend using protective films on particularly sensitive fronts such as foil-covered or glass fronts that do not leave adhesive residues. Soft padding, for example foam profiles on edges, helps prevent impact damage during loading and transport.
juMira46 schrieb:
After packing, clearly label all boxes and parts – this saves a lot of time and stress during assembly later.
This is an important tip that is often underestimated. Without clear labeling, there can be many questions that significantly prolong the move.
In conclusion: patience during disassembly and a well-planned packaging and labeling system are key to moving the IKEA Metod kitchen without damage.
