ᐅ What options are available to retrofit Ikea Besta doors with a soft-close feature?
Created on: 12 Feb 2022 08:43
curtli
curtli
12 Feb 2022 08:43
Hello everyone, I am planning to upgrade the doors of my Ikea Besta cabinet with a soft-close feature. Currently, the doors are simple hinged doors without any damping. Since the cabinet is used frequently, I want to enable a smoother, quieter closing without having to replace the entire door or the piece of furniture. My questions: What specific options are there to equip Ikea Besta doors with a soft-close function? Are there retrofit systems that can be combined with the existing fittings? How complex is the installation usually, and do I need to consider certain door widths or materials? I would be very grateful for tips on recommended products or personal experiences with such upgrades.
DUVIN
12 Feb 2022 09:15
There are soft-close hinges specifically designed for Ikea Besta that simply replace the existing ones. Alternatively, soft-close dampers with clamp or screw mounting can be attached directly to the doors. It is important to pay attention to the correct screw spacing. Installation usually takes about 20–30 minutes per door.
Lamar
12 Feb 2022 11:02
DUVIN schrieb:
There are soft-close hinges specifically for Ikea Besta that simply replace the existing ones.
One could argue that replacing hinges isn’t exactly a ‘retrofit’ but more of a modification. If you want that, you might as well order a door with integrated soft-close. But why Ikea doesn’t offer soft-close hinges themselves is a mystery to me. Is it just an attempt to cut costs? Retrofitting sounds good, but hopefully it doesn’t cost more than a new door.
Z
zartra
12 Feb 2022 14:27
In addition to replacing the hinges, there are also edge-mounted dampers that can be glued between the cabinet body and door. These are inexpensive but do not work as effectively as integrated soft-close hinges. Sufficient for simple applications but no substitute for a good hinge.
BOSULE
12 Feb 2022 16:45
There are a few important points to consider before retrofitting:
- Not all Besta doors are designed for soft-close hinges, so the compatibility of the drill holes is crucial.
- Attaching soft-close dampers with adhesive is easy, but the adjustment options are limited, which can result in less consistent closing behavior.
- High-quality replacement hinges from reputable manufacturers usually provide better damping and durability.
My advice: Check carefully before purchasing to see if there is a version specifically made for your door model.
Rhett
12 Feb 2022 18:10
BOSULE schrieb:
Attaching soft-close dampers is easy, but the adjustment options are limited
I can confirm that. I tried this method – it works, but not with the same ease of use as hinges. If smooth operation is important, it’s better to invest and replace the hinges.
