ᐅ What are the standard IKEA Metod dimensions for tall cabinets?
Created on: 25 Apr 2021 17:43
kobaleo
kobaleo
25 Apr 2021 17:43
I am currently planning my kitchen using the IKEA Metod system, and I have an important question: What are the standard dimensions for the Metod tall cabinets?
Specifically, I mean the most common height, width, and depth that are usually offered and serve as the basis for most kitchen plans. I’m particularly interested in whether there are significant differences between the various series or if IKEA follows a clear guideline that can be relied on.
For example, what are the typical measurements for tall cabinets designed to house appliances like ovens or refrigerators? Are there fixed standard sizes to keep in mind so that accessories or built-in elements can be integrated smoothly later on?
I look forward to concrete answers that will help me carry out my planning accurately.
glapu
25 Apr 2021 18:17
The standard dimensions for IKEA Metod tall cabinets are usually 60 cm (24 inches) wide and 60 cm (24 inches) deep. The height typically varies between 80 cm (31 inches) and 240 cm (94 inches), with 200 cm (79 inches) often being the standard.
There are special tall cabinets for ovens and appliances with a width of 60 cm (24 inches) and a height adjusted to fit the specific appliance.
FRANCISCOP
25 Apr 2021 19:05
In summary, the typical technical standard dimensions for IKEA Metod tall cabinets are:
- Width: 60 cm (24 inches), very common; some versions are also available in 40 cm (16 inches) or 80 cm (31 inches), though these are less frequent as tall cabinets.
- Depth: Generally consistent at 60 cm (24 inches) without doors, as the overall cabinet depth is based on this measurement.
- Height: The range includes tall cabinets of various heights between 80 cm and 240 cm (31 to 94 inches), with 200 cm and 220 cm (79 and 87 inches) being common standard heights for appliance integration or storage.
These dimensions follow a modular design approach, ensuring compatibility between different functional units such as ovens, tall cabinets with drawers, or refrigerators. For planning purposes, the 60x60 cm (24x24 inches) footprint is the most reliable basis.
For specific appliances with different dimensions, it is important to check the respective installation measurements and, if necessary, select special modules.
Ethan
26 Apr 2021 08:52
Hello kobaleo, to answer your question more precisely and in detail:
IKEA Metod tall cabinets are modular and follow defined standard dimensions that have proven reliable over the years.
Typically, IKEA uses the following measurements for tall cabinets:
- Width: Mainly 60 cm (24 inches), occasionally 40 cm (16 inches) or 80 cm (31 inches), although the latter are mostly used for base cabinet widths.
- Depth: 60 cm (24 inches) basic depth
- Height: The tall cabinets mainly differ here:
- Low tall cabinets (for built-in appliances like dishwashers) are about 80 cm (31 inches) high.
- Niche cabinets are about 220 cm (87 inches) high (the common standard height for oven and pantry cabinets).
- Taller sizes up to 220–240 cm (87–94 inches) are usual for fully integrated tall cabinets spanning several cabinet units.
It is important to note that IKEA’s planning is strongly based on the standard appliance sizes of German manufacturers, which makes installation easier.
If you want to install appliances, you should check the exact dimensions of these appliances before planning and then choose the appropriate tall cabinet accordingly.
I hope this helps you with your planning.
Giagau
26 Apr 2021 14:36
Ethan schrieb:
IKEA Metod tall cabinets are modular and actually follow defined standard dimensions that have proven reliable over the years.
That’s exactly the point. Another important aspect of standard dimensions is that the heights of Metod tall cabinets often vary in 20 cm (8 inches) increments to allow flexible combinations of different modules.
Additionally, it should be noted that IKEA often offers two depth options for tall cabinets: in some versions 37 cm (15 inches) for open shelves or appliances, and generally 60 cm (24 inches) as the common standard. However, if you plan for frosted glass or integrated fronts, 60 cm (24 inches) is usually the norm because it provides optimal storage space.
Very important: the dimensions refer to the cabinet carcass; doors or panels with varying thicknesses are added on top, which must be taken into account when considering the total depth. The widths have settled at 40, 60, or 80 cm (16, 24, or 31 inches).
So, anyone who wants every detail exactly right should consult IKEA’s planning guide or check the samples in person, but 60 cm (24 inches) width and 60 cm (24 inches) depth are essential standard dimensions for tall cabinets in the Metod system.
