Hello everyone, I have an issue with the doors of my BILLY shelving unit; sometimes the hinges squeak when opening or closing them. The noise is quite annoying, and I suspect it might be due to insufficient lubrication or a misaligned hinge. Since I’m looking for a clean and lasting solution, I’m reaching out to this community:
What methods or products have you found effective in stopping the squeaking of BILLY doors or their hinges?
I would appreciate any tips, including advice on maintenance intervals or necessary preparatory steps for cleaning or servicing the hinges.
To eliminate squeaky BILLY doors or hinges, I recommend the following steps:
1. Cleaning: Remove dust and dirt with a lint-free cloth, possibly using a small amount of rubbing alcohol for stubborn residues.
2. Lubrication: Use a silicone-based lubricant or a specialized furniture or door lubricant. Silicone spray is advantageous as it does not stick and does not attract dust.
3. Adjustment: Check the hinges for proper alignment and, if necessary, tighten the screws to relieve any stress that may cause mechanical noises.
Regular maintenance, approximately every six months, can extend the lifespan of the hinges and prevent recurring squeaking.
Here is a short guide on how to systematically address squeaking doors on BILLY cabinets:
1. Remove the door: For BILLY cabinets, this is usually straightforward—just unhook the door.
2. Clean the hinges: Use a lint-free cloth and a mild cleaning agent or isopropyl alcohol to remove old residue of oil, dust, and dirt.
3. Choose a lubricant: I have found grease to be effective, as it stays on the metal surface and works long-term. Alternatively, silicone spray can be used if you want a quick fix.
4. Apply: Put a thin layer of lubricant on the moving parts of the hinges.
5. Adjust: Do not tighten screws too much; a bit of play allows for noise-free movement.
6. Rehang the doors and open/close them several times to allow the lubricant to work in.
Important: Do not use WD-40, as it cleans more than it lubricates and can make the problem worse over time. The durability of the lubrication depends on usage, so check more often in the case of heavy use.
usbla schrieb:
Using a silicone-based lubricant or a special furniture or door lubricantThis is certainly a well-established recommendation, but I wonder if silicone spray is always the best choice. Some people complain that it attracts dust and, due to its rather cleaning effect, the problem returns after some time.
Jensson schrieb:
Don’t use WD-40, as it cleans more than it lubricatesI think this point is also important to emphasize.
Has anyone tried alternatives that last longer, such as Teflon-based lubricants? Or perhaps a mechanical adjustment of the door to prevent squeaking? What are your thoughts?
