ᐅ What should I do if my Billy shelves are wobbling?
Created on: 25 Oct 2021 08:47
marme
Hello everyone, I have a somewhat specific issue: I’ve noticed that my Billy bookcases from the IKEA range, which I have been using for some time, wobble when touched or under light load. Since I mainly use them for books and decoration, the wobbling is not only visually unsettling but also raises concerns about stability and safety in daily use.
Does anyone have any idea what the most common causes of this wobbling are? I am particularly interested in whether it can be fixed with simple measures like tightening screws or adding extra fasteners, or if it might be due to a design issue.
Also, what are your experiences with the overall stability of Billy bookcases, and are there any recommended tips to prevent wobbling in the long term? I look forward to any advice and shared experiences!
Dopoki
26 Oct 2021 07:58
In summary, the wobbling of the Billy shelves mainly results from the lack of wall anchoring and uneven weight distribution. The construction itself is solid but not designed for high load stress without additional fixation.
A verified, level base is essential. Unevenness can be compensated with felt pads or small shims.
If drilling holes is to be avoided, clamping devices, anti-slip mats, or Velcro solutions can be used, although their holding strength is limited. For maximum safety, always use the supplied brackets.
Another point is to check the shelf’s screws and joints, as loosened fittings affect the feeling of stability.
nanidra
26 Oct 2021 11:03
marme schrieb:
Does anyone here maybe have an idea what the most common causes for this wobbling are?
The wobbling often comes less from the shelf itself and more from improper use or expectations. Billy shelves are generally not designed as heavy-duty furniture. So if you really load them with heavy items or move them around constantly, they will wobble—this is not a design flaw but physically understandable.
Instead of focusing on the number of screws, you should consider whether the location and intended use are appropriate. Sometimes it helps more to adjust your expectations than to try to force greater stability.
fikeo
26 Oct 2021 14:22
nanidra schrieb:
Billy shelves are basically not designed as heavy-duty furniture
I agree, but I would like to add: For normal use—books, folders, decorations—Billy shelves are very suitable, as long as the weight is distributed evenly and the shelves are properly assembled and secured.
If you regularly store very heavy or bulky items, you should opt for sturdier systems or add additional reinforcements. In any case, regular inspection of the fasteners is advisable to prevent wobbling.
