Hello everyone, I have a somewhat specific issue: I’ve noticed that my Billy bookcases from the IKEA range, which I have been using for some time, wobble when touched or under light load. Since I mainly use them for books and decoration, the wobbling is not only visually unsettling but also raises concerns about stability and safety in daily use.
Does anyone have any idea what the most common causes of this wobbling are? I am particularly interested in whether it can be fixed with simple measures like tightening screws or adding extra fasteners, or if it might be due to a design issue.
Also, what are your experiences with the overall stability of Billy bookcases, and are there any recommended tips to prevent wobbling in the long term? I look forward to any advice and shared experiences!
marme schrieb:
I’m especially interested to know if this can be fixed with simple measures like screwing it down or adding extra connectorsHello marme, yes, in most cases the wobbling is caused by insufficient fastening, especially if the shelf is not fixed to the wall. The Billy shelves are generally sturdy, but they are primarily designed for indoor use and light to medium loads.
I strongly recommend using the included wall brackets. These ensure a secure standing. Additionally, you can add screws or angle brackets yourself to reinforce the connections between the shelf components. This noticeably improves stability.
If the shelves do not fit properly or have play, additional wooden dowels or small clips can help reduce wobbling. Also, placing and adjusting the unit on a level surface is important, as uneven floors often cause wobbling.
fikeo schrieb:
If the shelves don’t fit properly or have some playThank you for the helpful advice, especially regarding the use of anchors and brackets. In my case, it seems that the side panels have a slight gap between them, causing the entire shelving unit to wobble a bit when loaded.
I haven’t actually fixed the shelves to the wall yet, as I prefer not to damage the walls in my rental apartment. Are there alternative ways to securely stabilize the shelves without drilling? For example, with clamping or tension devices?
Also, how important is the weight or the even distribution of items on the shelves for stability?
marme schrieb:
Are there alternative ways to securely stabilize shelves without drilling directly into the wall?Hi marme, of course! If you really want to avoid making holes in the wall, there are a few clever options.
A simple solution is so-called "furniture stabilizers" or anti-tip devices that don’t require drilling. Sometimes, double-sided adhesive tapes from hardware stores can provide enough support if you’re not placing the heaviest books on the shelves.
And remember: the more weight on top, the higher the tipping risk. So try to store heavy items on the lower shelves. And if it still wobbles, just have a little fun with a hammer drill battle 😉 just kidding— with the right weight distribution and more secure feet, it should be stable! :-)
