ᐅ What DIY guides are available for Ikea Brimnes?
Created on: 17 Aug 2021 09:13
Meonau
Hello everyone, I am currently exploring different ways to customize or modify Ikea Brimnes furniture pieces using DIY guides. I am particularly interested in practical, well-documented projects related to the Brimnes series, such as dressers, beds, or cabinets. Does anyone here know of instructions or experience reports on how to change the color, structurally expand, or functionally enhance Brimnes items? Tips on suitable materials or tools that work especially well are also welcome. Therefore, my question is: What DIY guides exist for Ikea Brimnes that add value without fundamentally damaging the furniture?
Surela
18 Aug 2021 08:47
Meonau schrieb:
can you briefly explain how well these perform on the rather smooth MDF surfaces from Ikea?
Sure. Chalk and lime paints adhere well to MDF if you lightly sand the surface beforehand (grit 180-220). Priming is recommended to prevent the paint from soaking in too much. The advantage: chalk paint is breathable, has a nice matte finish, and can be sealed with special wax—which also protects against abrasion. If you want a reversible finish, a thin protective layer of clear wax is the best choice, because the paint itself can be removed quite easily with water and sandpaper without damaging the substrate.
If you prefer a quicker solution: high-quality masking tape and water-based spray paint in satin finish are also options; however, removal is often a bit more involved.
What kind of paint were you specifically considering?
GIPAPO
18 Aug 2021 10:15
Alternative: Replace the handles. There are many guides available on how to refresh Brimnes dressers with different handles – much easier than painting and provides a highly visible effect.
Dwight49
18 Aug 2021 11:57
When modifying Ikea Brimnes furniture, I particularly recommend the following well-established DIY guides:
- Remodeling drawer fronts with real wood veneer to improve both feel and appearance. Note: This requires precise cutting and gluing.
- Reinforcing the bed frame by adding extra metal brackets; this significantly increases stability.
- Installing LED strips under the top edges of dressers, with a separate built-in switch.
- Replacing the hinges with soft-close versions for smoother operation.
These methods are documented in various DIY forums and result in durable improvements. The advantage is enhanced functionality without losing the basic character of the furniture.
Meonau
18 Aug 2021 14:03
GIPAPO schrieb:
Alternative: replace the handles.
That is actually a simple but effective option. I’m curious whether replacing the handles on the Brimnes dresser is possible without further adjustments to the drill holes—or if you often have to do some modifications?
Surela schrieb:
What exact color are you thinking of?
I’m leaning toward a muted dark gray to give the dresser a more modern look without being too striking. Therefore, it would be interesting to know how readily chalk paint shades in this range are available and whether they provide good coverage.
KAUDRA62
19 Aug 2021 09:21
Hello Meonau, a little wink: Sometimes it’s the small details that turn a simple piece of furniture like the Brimnes into a real design gem – all without major renovations!
Changing handles? Check. Adhesive films in stylish colors? Check.
Definitely try this: Highlight small details, like new knob handles or an inset strip with film – it looks really fresh and keeps things flexible.
And for the dark gray: take a look at matte films, they look very elegant and also protect against scratches. Really sparks creativity!
