Hello everyone, I am interested in the Brimnes range from IKEA, specifically in combining BRIMNES furniture with other IKEA series. My question is: Can I visually and functionally combine BRIMNES furniture, such as beds, dressers, or wardrobes, with other IKEA furniture series in my bedroom without any issues? Are there any potential problems regarding dimensions, color tone, or materials that I should be aware of? Is there any experience with common mix-and-match combinations, for example with Malm or Hemnes? I would greatly appreciate any tips on selection and possible pitfalls.
First of all, a warm welcome to the forum!
Regarding your question: BRIMNES is a series that can indeed be combined well with other IKEA furniture, but there are a few things to keep in mind.
- Color tone: BRIMNES is mostly available in white or black-brown; the white tone is slightly more matte than, for example, the MALM white, which can be noticeable when placed side by side.
- Dimensions: BRIMNES beds sometimes have different frame heights or headboard shapes compared to, for example, MALM, so it’s best to measure carefully in advance whether other pieces like nightstands or dressers visually harmonize.
- Materials: BRIMNES mainly uses particleboard with a melamine coating, which can differ from the somewhat more solid HEMNES pieces; this can sometimes be seen in the surface texture.
Conclusion: A combination is possible both visually and functionally, but if you’re aiming for the most uniform look, I would recommend checking samples at IKEA in person or arranging the furniture in the room beforehand. Good luck with your planning!
In addition to giabau’s points:
- The dimensions of BRIMNES beds, for example, follow standardized sizes, but the frame height differs from MALM or other series. This may limit compatibility with accessories such as bedspreads or box spring beds.
- In terms of appearance, the white color of BRIMNES is slightly off-white, whereas other series sometimes have a purer white. This results in a subtle but noticeable difference in shade.
- Material-wise, BRIMNES is more budget-friendly, which is reflected in the feel and quality.
In short, it’s not a problem to mix BRIMNES with other series as long as you are aware of the small differences and take them into account when purchasing and arranging the space.
To answer your question in more detail:
When combining BRIMNES with other IKEA series, you should especially pay attention to the following points:
- Color differences: Not all whites are the same. BRIMNES has a matte white with a slight yellowish tint, while series like MALM often feature a more neutral white with a bit more gloss.
- Design lines: BRIMNES focuses on more modern, simple lines without much decoration. Series like HEMNES have a slightly more classic design with rounded edges and ornamentation, which can create a stylistic clash.
- Functional compatibility: Drawer sizes, interior fittings, and fastenings can differ. For example, if you want to combine drawers or interior inserts, it’s worth carefully comparing the measurements.
Personally, I have combined BRIMNES with MALM in one room, and it works well as long as you pay attention to the details. If you want the entire room to look visually cohesive, I would recommend at least matching the color tones or adding accents that link both series.
giabau schrieb:
BRIMNES is usually available in white or dark brown; the white shade is slightly more matte compared to, for example, the MALM white, which can be noticeable when placed side by side.Thank you, that is already very helpful information. In my bedroom, the shade of white is particularly important as I want to avoid any distracting color differences. I’m curious if there is a way to bridge the color variation, perhaps through accessories or lighting?
And regarding the differences in materials: how significant is the difference in practice? Is it mainly a cosmetic issue, or could it affect durability or maintenance?
