ᐅ Is it possible to extend IKEA Brimnes furniture with custom-built add-on components?
Created on: 8 Nov 2024 09:13
Mutan37
I would like to know if it is possible to extend the IKEA Brimnes furniture with custom-made add-on parts. Specifically, I am interested in whether the construction method and materials of the Brimnes system are stable enough to support additional shelves, upper cabinets, or other elements that are self-made or customized and mounted on top. Are there any experiences regarding the connection points and whether the furniture can be safely extended without professional workshop equipment? It is especially important for me to know if the assembly can be modified in such a way that the furniture remains stable and maintains its load-bearing capacity after the extension.
Davidleo
8 Nov 2024 11:13
I did exactly that! I placed a second Brimnes dresser on top of my dresser and secured it from the inside with metal brackets. It works very stably and looks great. It’s important to screw the lower screws into the side panels, not just the back panel. This holds incredibly well and can support quite a bit of weight. I highly recommend it!
nolan
8 Nov 2024 11:29
Building extension parts yourself can work, but the risk of tipping increases. Simply stacking and connecting two dressers is usually safer because the furniture is already stable from the factory. If the extensions are custom-built, make sure that the load is evenly distributed.
Paunon
8 Nov 2024 12:04
Anyone doing extensions themselves should always consider load distribution. If add-on parts are too large or heavy, it is better to choose secure connections to the wall. Otherwise, there is a risk of tipping.
KAULIS
8 Nov 2024 12:38
Regarding the structural integrity when building add-on units for IKEA Brimnes: The side panels are made of medium-density fiberboard (MDF) with a thickness of approximately 15 mm (0.6 inches), while the back panel is thinner and less load-bearing. Therefore, fastenings should preferably be made into the side panels, as they bear the main load. A custom-built add-on should not carry excessive weight and must be evenly supported. Additional metal brackets and screws help to increase stability. It is also recommended to secure the unit to the wall to minimize the risk of tipping, especially for taller constructions.
Mutan37
8 Nov 2024 13:12
Thank you for the feedback. In summary, the side panels of the Brimnes series seem to be the only solid option for secure attachment, with the back panels being less reliable. The idea of stacking two dressers connected with metal brackets and screws into the wood sounds sturdy. Nevertheless, I plan to create a custom top structure made from 18 mm (0.7 inch) MDF, which will be attached using screws and brackets. It is important for me to ensure stability because the top unit will also include shelves. Does anyone know of an effective solution to secure such a top against tipping and shifting without causing significant damage to the furniture?
blapau
8 Nov 2024 13:40
Mutan37 schrieb:
Does anyone know a suitable solution to effectively secure such an attachment against tipping and shifting without causing significant damage to the furniture?
A proven method is to attach a flat metal strip or mounting plate to the back of the furniture, in addition to the existing joints, which is then fixed to the wall. This secures the furniture against tipping without damaging visible surfaces. Additionally, small angled brackets can be installed on the sides, which remain hidden but provide extra stability.
