ᐅ What can I do if parts are missing during the assembly of the PAX system?
Created on: 7 May 2015 18:42
DeoerlindaD
Deoerlinda7 May 2015 18:42Hello everyone, I recently assembled a Pax wardrobe from IKEA and unfortunately found that some parts were missing. My question is: what exactly can I do if parts are missing during the assembly of a Pax furniture piece? I have already checked the packaging and the box itself but could not find any additional parts. I would also like to know if it’s possible to rely on goodwill from IKEA, how the process of obtaining replacement parts typically works in such cases, and whether it makes sense to pause the assembly at that point or continue building and get the missing parts later. It would be helpful if you could share detailed advice based on your own experience or common practices. Thanks in advance!
Deoerlinda schrieb:
What can I specifically do if parts are missing during the assembly of a PAX furniture unit?Hello Deoerlinda, I generally recommend staying calm first, as such situations can usually be resolved well. If parts are missing, the first step is always to carefully check the packaging and the box again – sometimes smaller parts are hidden in protective bags or cardboard inserts.
If you still cannot find the parts, you can order replacements directly from IKEA. Their website offers a very user-friendly spare parts order system. There, you enter the article number of the PAX wardrobe and specify the missing parts.
It is important to check the parts description in the manual before ordering and, if possible, have photos of the missing parts ready. Sometimes it is also worthwhile to visit the nearest IKEA store if it has a customer service area, as they usually respond more quickly there.
Regarding your question about whether to stop assembly at the point where parts are missing: I would recommend continuing to build as far as possible. This way, you keep track of which components are missing and can communicate this more effectively.
If you have any other questions, feel free to ask!
Johnathon8 May 2015 07:53erikpu schrieb:
It is important to check the part description in the manual before placing an orderI agree with that and would like to add a bit more detail: For PAX wardrobes, the available replacement parts include individual screws, hinges, dowels, as well as complete components like doors or side panels. The manual or the online manual is your most important tool to accurately identify which parts are missing.
I would also strongly recommend knowing exactly which version of the PAX wardrobe you have before ordering replacement parts, as IKEA updates the product lines from time to time. This means that replacement parts are not always compatible if it is an older wardrobe.
Another tip: If you are currently assembling, note down the wardrobe’s serial number/item number and, if possible, the numbers listed directly on the assembly instructions. IKEA often uses specific part numbers (these can usually be found on individual instruction sheets or on the wardrobe itself).
Deoerlinda schrieb:
whether it makes sense to pause the assembly at this point or continue right awayPersonally, I would pause the assembly as soon as a critical part is missing that could prevent the installation of further components. An incorrect assembly without the correct part can lead to problems or even damage later on. However, if you are sure that missing small parts will only be needed later, you can continue assembling.
I would also be interested to know exactly which parts you are missing. Screws, hinges, panels? That could help provide more precise advice.
Johnathon schrieb:
I’m also curious: Which exact parts are you missing? Screws, hinges, panels?Hey, I’ll add a practical perspective here: If you’re only missing a few screws or connectors, check if you can replace them at a hardware store or with spare parts from a “screw box” elsewhere, especially if it’s urgent. However, these kinds of improvised fixes aren’t always ideal, depending on how they might affect the cabinet’s weight capacity or stability.
For larger parts, I would never recommend DIY replacements, as that can quickly lead to problems.
IKEA customer service is usually very accommodating and often sends missing parts free of charge. In my experience, having your box and receipt number on hand makes the process much smoother.
Last but not least: If you want to make the most of your assembly time, try to reconstruct the parts list or look up your PAX model online. That way, you can prepare the order while taking a break and avoid wasting time.
Hope this helps shed some light on the situation!
