Hello everyone, I would like to get a fairly precise estimate: how long does it typically take for an average DIY person to assemble IKEA Pax wardrobes without professional help? I’m not interested in the fastest times or extreme cases, but rather the realistic timeframe needed to assemble a medium-sized Pax wardrobe (for example about 2 meters (6.5 feet) tall and 1 meter (3.3 feet) wide, with standard doors). It is also relevant whether the time includes sorting and preparing the parts before assembly, as well as installing the doors and possibly the shelves. I look forward to hearing about your experiences and any tips on how to use the time most efficiently.
The average assembly time for a medium-sized Pax wardrobe is typically between 2 and 4 hours, based on multiple user reports. It should be noted that this assembly time refers only to the actual construction, excluding any preparation. Preparation, such as laying out and sorting the parts, can take up to 30 minutes longer depending on how well-organized the process is. Installing doors, especially those with a soft-close feature, usually adds about 30 minutes to the total time. To assemble efficiently, it is recommended to sort all screws and connectors in advance and check that everything is complete.
To answer the question in more detail, I would like to briefly outline the individual work steps that determine the time required:
- Preparation: Sorting all wooden parts, screws, dowels, and hinges, checking for completeness (about 20-30 minutes).
- Assembly of the basic frame: Fitting and screwing the cabinet components together; here, the type of surface also affects the ease of work (about 1.5 to 2 hours).
- Installation of the back panel: This is often delicate and requires careful handling, about 20 minutes.
- Installation of shelves and interior fittings: Depending on the quantity, about 15-30 minutes.
- Installation of the doors: This depends greatly on the model and experience; soft-close doors need careful adjustment – 30-60 minutes.
In addition, unpacking the boxes and cleaning up should not be underestimated.
Depending on the skill level and the number of helpers, the time required can decrease or increase significantly. If you like, you can add information about your experience level and assistance during assembly, so more targeted advice can be given.
Thank you for the detailed assessment. To respond to your last comment: I have basic DIY skills and have assembled smaller flat-pack furniture before, but I am not a professional. I will assemble the Pax wardrobe on my own without any additional help. The doors are standard hinged doors without soft-close, and the wardrobe itself is quite standard, about 2 meters (6.5 feet) high and 1 meter (3.3 feet) wide. Your breakdown helps me a lot in better understanding and estimating the individual steps.
Given the specified conditions (assembly done alone, standard hinged doors without soft-close, average DIY skills), you should realistically allow about 3 hours for the entire assembly. It is advisable to follow the assembly instructions carefully during the work to avoid time loss due to mistakes. Additionally, I recommend sorting all parts and tools thoroughly before starting, as mentioned earlier, so you don’t have to keep bending down or searching, which saves unnecessary breaks.
Genevieve28 Apr 2022 14:45A quick question: How reliable are the estimates of 2 to 4 hours? Are there any solid surveys or studies on the average assembly time for Pax wardrobes, or are these just based on individual experiences? I’m not criticizing, but I have the impression that the time varies significantly depending on personal circumstances and the complexity of the chosen configuration. Could this be differentiated in more detail?
