ᐅ What assembly aids are available for building IKEA PLATSA furniture?
Created on: 3 Feb 2017 19:42
KAGLAHello everyone,
I am currently assembling IKEA Platsa furniture and have come across an interesting question: What assembly aids or tools are available specifically for building Platsa that can make the process easier or faster?
I am especially interested in whether there are any specialized tools beyond the basic screwdrivers and hammers included in the package, or if there are proven aids that have been shown to be particularly useful in practice.
Additionally, it would be helpful to know if there are any assembly aids that support precise alignment of the individual modules, or solutions for common issues such as misaligned joints or difficult screw positions.
I would greatly appreciate any experiences or recommendations, including tips on affordable tools to purchase, as well as advice on when using such assembly aids is truly worthwhile.
Thank you in advance!
Hello KAGLA,
good and very specific question! The IKEA PLATSA assembly is generally well designed, but some mounting points can be tricky.
Here’s a brief overview of assembly aids I can recommend from my own experience:
- Cordless drill with a Phillips bit: Saves a lot of time, especially given the many screws.
- Angle guide or metal square: For precise right-angle alignment of module parts.
- Rubber mallet: Prevents damage to wooden parts when gently tapping connections into place.
- Clamps or securing tools: To hold components firmly during assembly.
- Assembly jig or homemade templates: For consistently accurate positioning, for example of dowel holes.
It’s also important to follow the systematic approach outlined in the instructions. Some people lay out all parts side by side and check them first, which can save time and frustration.
For misaligned joints, gently readjusting with light taps and pointed screwdrivers can help when dowels don’t fit exactly.
If you like, I can write you a small guide later on common mistakes during PLATSA assembly.
Best regards!
Best regards!
To be honest, it bothers me a bit that there are always tools being promoted here as miracle solutions.
That’s true, but IKEA intends for their furniture to be assembled with minimal tools. Often, you don’t need more than a simple screwdriver.
I think one of the best “assembly aids” is simply patience and carefully reading the instructions. Everything else turns the IKEA experience into a high-tech construction site.
And honestly, how often do you really need a special tool for assembly? Sure, if you build furniture professionally, but at home?
I believe it’s a bit of effort that is often justified out of convenience rather than actual necessity.
rotofra schrieb:
Cordless screwdriver with a Phillips bit: Saves a lot of time, especially with so many screws.
To add to the previous comments:
Some fittings and screw connections on PLATSA furniture are designed quite tight, which can make using a cordless drill without a gentle touch challenging.
Therefore, I recommend a torque-controlled tool or at least a screwdriver with low torque to prevent overdriving screws.
There are no special IKEA tools for precise alignment, but standard carpenter’s squares and folding rulers work accurately for this purpose.
Spacer strips can also be helpful when modifying and joining multiple units together.
For a professional level of precision, you can also create self-adhesive alignment markers to ensure repeatability.
[@KAGLA] Here are a few practical tips that might help you during assembly:
1. Partially screw in all screws first before tightening them fully. This prevents the parts from becoming misaligned and difficult to position.
2. For deep drill holes, it’s best to use a drill stop (e.g., heat shrink tubing on the drill bit) to avoid over-rotating the anchors.
3. A pruning shear or small pipe wrench can help with screws at awkward angles when the screwdriver doesn’t grip well.
4. If you’re working alone, positioning the parts on a non-slip surface can help prevent them from sliding around.
Regarding assembly aids, I recommend checking out either IKEA’s own or third-party clamping tools that make securing multiple modules easier.
If a detailed list of sources would be helpful, I’d be happy to provide one.
bareynaldo4 Feb 2017 14:42I always find it quite exaggerated when people say you need expensive specialized tools for IKEA furniture.
Exactly, I mean, you’re buying furniture designed for the average customer – and then some “professional” comes along with angle guides and assembly jigs.
Honestly, most of the time you just need a level and a screwdriver, and that’s it.
Sure, if you’re nailing a large IKEA PLATSA cabinet to the wall, maybe you need a bit more, but otherwise?
I think people sometimes underestimate the simplicity that IKEA intentionally designs into their products.
NOAHSAU schrieb:
I think it’s often an effort justified by convenience rather than actual necessity.
