ᐅ What are the most common issues when assembling the IKEA Hemnes?
Created on: 28 Apr 2017 19:27
petru
petru
28 Apr 2017 19:27
I would like to use this thread to collect the most common problems you have encountered when assembling the IKEA Hemnes furniture series. From my experience, despite the apparent simplicity, the instructions and the fit of some components often lead to frustration. I am particularly interested in issues that go beyond obvious problems like missing parts or damaged materials, focusing instead on technical or methodological difficulties during assembly itself. For example, whether certain screws or connectors are difficult to handle, if the clarity of the instructions is really sufficient, or if adjusting the doors repeatedly causes problems. I would appreciate it if you could share your specific experiences and solutions so that we can create a solid knowledge base for future assemblies.
Thank you in advance!
DUVIN
28 Apr 2017 20:13
The most common issues when assembling Hemnes are usually:
- Screws that don’t catch properly
- Doors that are difficult to adjust
- Drill holes that are sometimes not perfectly aligned
I recommend always laying out the parts first and reading the instructions carefully.
risar
29 Apr 2017 08:42
Hello petru and everyone else,
Your question is very well put and gets to the heart of the matter. I have assembled the Hemnes several times and can confirm that the instructions often cause confusion. Many people are familiar with the issue that the pictograms are not always clear, which can lead to assembling parts in the wrong order.
Furthermore, installing the drawer runners can sometimes be challenging because they need to fit quite precisely. The screw quality is generally acceptable, but it helps to use a good screwdriver to secure the connections properly.
A tip: Assemble the furniture in a large, tidy space and double-check intermediate steps.
How do you handle the adjustments of the doors? Do you find any particularly tricky spots?
TuLaurent
29 Apr 2017 10:57
risar schrieb:
How do you handle door adjustments? Do you find any particular tricky spots?
I can relate to that well. For me, the doors were the biggest challenge with the Hemnes. After assembly, they often didn’t align perfectly – which was pretty frustrating, and I was worried I had done something wrong. Making a few adjustments, taking a short break, and then trying again helped me. Don’t lose confidence; many people experience this. In the end, it usually fits properly.
I really appreciate your detailed question because it helps us identify common issues and work on them more effectively. Thanks for that!
karpu3
30 Apr 2017 15:22
Typical issues include:
- unclear instructions for drawer slides
- sometimes small locking plates or screws are missing (check these in advance)
- if doors are not properly aligned, it’s better to loosen everything and start over
Most problems can be solved with some patience and assembling with two people.
ritotar
1 May 2017 09:11
Actually, the Hemnes is quite a likable piece, but assembling it can really throw a wrench in the works. The instructions sometimes feel like they’re sending you a puzzle in hieroglyphs – a wink here and a missed screw there, and suddenly the cabinet ends up crooked.
I always recommend allowing plenty of time and maybe playing your favorite song in the background. That way, you don’t lose your smile, even if the doors don’t quite fit perfectly. And hey, if a part doesn’t fit, just take a deep breath and approach it with a sense of humor.
Has anyone ever had a particularly tricky problem with the instructions that ended up being solved by a simple trick? I’m curious to hear about your little “aha” moments!
