ᐅ Unifi NanoHD on a Concrete Ceiling – What Type of Junction Box Should Be Used?
Created on: 6 Nov 2020 13:32
BananaJoe
I’m wondering what type of mounting box would be best to install in a precast concrete ceiling to easily mount a Wi-Fi access point (the plan is to use a Unifi NanoHD, or possibly the already available Access Point AC Pro for now) without a suspended ceiling.
The architect suggests a HaloX 180, but that seems a bit excessive to me. Especially if, at least in the longer term, the NanoHD is going to be mounted on the ceiling. It only has a diameter of 16cm (6.3 inches) and therefore might not fully cover the HaloX or its mineral fiber panel.
Is it possible to install a standard flush-mounted box in such a precast concrete ceiling (apparently from Dennert, if that’s relevant)? I imagine it could be used to house the CAT cable, keystone jack, and a short patch cable, with the access point then installed on top. Would there be enough space for that?
Are there any better solutions?
Thanks in advance!
hanse987
27 May 2021 13:54
Stefan2.84 schrieb:
I have also considered printing. But I wonder if the print might break when screwing?!
You don't have to tighten the mounting plate fully. Hand-tight is enough! Possibly use a bit more material around the screw area.
Tassimat
27 May 2021 13:54
On Thingiverse, you can find adapters under the keyword NanoHD. For example, under the ID 4090734.
Screws hold very well in 3D prints. They don’t need to support much weight, and screw holes are usually already included in the models.
Without a 3D printer, I would cut a thick wood board using a fret saw. In less visible areas, a jigsaw would also work. Afterwards, sand everything and paint it white.
It’s just a circle for the outer diameter and a rough inner circle to make space for the cable.
K1300S27 May 2021 14:08
I’m not sure how it is with the Unifi APs, but there might even be a mounting ring included that can be used as a template.
Stefan2.84
27 May 2021 14:16
I quite like the pressure. It's a great idea. However, I don’t want the cable to run out of the adapter like in the example anymore. But that can be adjusted. The mounting ring can really serve as a template for that. I’ll have our designer draw it up then.
opalau27 May 2021 14:18
Stefan2.84 schrieb:
I remember someone here has done this before. Unfortunately, I can’t find any ideas on how to build or implement it easily and with minimal effort. Does anyone have an idea or, better yet, a ready-made solution that I can replicate exactly?
I assume you mean my post here? https://www.hausbau-forum.de/threads/lan-dosen-setzen-noch-zeitgemaess-wlan-drahtlos-ist-die-zukunft.33656/post-445713
Stefan2.84
27 May 2021 14:30
That's exactly what I meant. I think it's cool. However, I'm hesitant because I don't have the right tools or the (probably) required DIY skills. So, the pressure method is really a great alternative.
Were the ordered boards 18cm (7 inches) in diameter? Where did you order them from?
