ᐅ Unifi NanoHD on a Concrete Ceiling – What Type of Junction Box Should Be Used?
Created on: 6 Nov 2020 13:32
BananaJoe
I’m wondering what type of mounting box would be best to install in a precast concrete ceiling to easily mount a Wi-Fi access point (the plan is to use a Unifi NanoHD, or possibly the already available Access Point AC Pro for now) without a suspended ceiling.
The architect suggests a HaloX 180, but that seems a bit excessive to me. Especially if, at least in the longer term, the NanoHD is going to be mounted on the ceiling. It only has a diameter of 16cm (6.3 inches) and therefore might not fully cover the HaloX or its mineral fiber panel.
Is it possible to install a standard flush-mounted box in such a precast concrete ceiling (apparently from Dennert, if that’s relevant)? I imagine it could be used to house the CAT cable, keystone jack, and a short patch cable, with the access point then installed on top. Would there be enough space for that?
Are there any better solutions?
Thanks in advance!
Thanks in advance!
I don’t understand why there’s so much effort involved. Just have a 180mm (7-inch) electrical box installed, then drill the appropriate hole later and conveniently store everything inside the box.
This even has an advantage: you can use it as a mini safe to hide things 😉.
If not, Golfi’s solution is also okay.
This is how the NanoHD looks from the back.
hanse987 schrieb:
Even if the NanoHD works now without a back box, eventually it will reach its end of life, and a new model might not have this cavity. Then, in a few years, you could be in a difficult position looking for solutions or facing very limited options.Well. You can’t prepare for every possible future scenario in life.
In the end, it’s a matter of cost.
MBPassion10 Nov 2020 19:42We are currently facing the same challenge, and drilling a deep hole into the concrete ceiling was no fun for the electrician (actually, no fun three times over). However, I believe the best solution is to install a deep flush-mounted box to allow for more flexibility. It currently looks like this:
The box has a depth of 8cm (3 inches). I have also already sourced both angled keystones and patch cables with one angled end. But I suspect it should also work fine with a normal keystone and a short patch cable.
