ᐅ Unifi NanoHD on a Concrete Ceiling – What Type of Junction Box Should Be Used?
Created on: 6 Nov 2020 13:32
BananaJoe
BananaJoe
6 Nov 2020 13:32
I’m wondering what type of mounting box would be best to install in a precast concrete ceiling to easily mount a Wi-Fi access point (the plan is to use a Unifi NanoHD, or possibly the already available Access Point AC Pro for now) without a suspended ceiling.
The architect suggests a HaloX 180, but that seems a bit excessive to me. Especially if, at least in the longer term, the NanoHD is going to be mounted on the ceiling. It only has a diameter of 16cm (6.3 inches) and therefore might not fully cover the HaloX or its mineral fiber panel.
Is it possible to install a standard flush-mounted box in such a precast concrete ceiling (apparently from Dennert, if that’s relevant)? I imagine it could be used to house the CAT cable, keystone jack, and a short patch cable, with the access point then installed on top. Would there be enough space for that?
Are there any better solutions?
Thanks in advance!
AMNE3IA6 Nov 2020 14:50
We used the 180mm (7 inch) junction box. Depending on whether you have other flush-mounted boxes aligned, I would recommend choosing a larger size rather than a smaller one to allow some room for adjustment. Our boxes weren’t installed that precisely, so I was glad to have some extra space. Using a standard flush-mounted box won’t necessarily be much cheaper. If desired, you can recess the Nano up to halfway inside a larger box.
Pinky03016 Nov 2020 18:52
Does it have to be mounted on the ceiling? We install our APs on the wall just below the ceiling. Maybe that’s easier or better?
Ötzi Ötztaler
6 Nov 2020 19:29
We do the same, using a sufficiently large junction box at the top of the wall. Conveniently, the screw hole spacing of the junction box matched the nanoHD perfectly, so I didn’t even need to drill for the installation. I just had to notch a small corner in the plastic mounting bracket for the cable.
hanse987
6 Nov 2020 20:50
The antennas of the nanoHD are optimized for ceiling installation. For wall installation, I would opt for the In-Wall model.
BananaJoe
6 Nov 2020 21:18
hanse987 schrieb:
The antennas of the nanoHD are optimized for ceiling installation. For wall mounting, I would go for the In-Wall version.
That’s exactly why (antenna orientation) I also want to mount it on the ceiling!
AMNE3IA schrieb:
If you want, you can recess the Nano up to halfway in a larger electrical box.
Wouldn’t that affect the antenna radiation pattern if half of the access point is inside the ceiling?
