ᐅ Transporting BILLY Shelves Without Damage – Tips and Tricks
Created on: 18 May 2022 08:34
Mishel
Mishel
18 May 2022 08:34
I am currently facing the challenge of transporting a Billy bookshelf from IKEA without causing any damage. The bookshelf measures approximately 80x28x202 cm (31½x11x79½ inches) and, as usual, is made of particleboard with a melamine-coated surface. Unfortunately, the bookshelf is a bit older and no longer in its original packaging.
My question is: which specific precautions should I take during transport to avoid scratches, dents, or other damage?
Additionally, I would like to know if you have any tips on how to secure the bookshelf while carrying it to prevent instability and protect the joints. Any advice on fixing it properly in the transport vehicle is also welcome.
I look forward to your practical experiences and suggestions, as this bookshelf is really important to me.
Thank you in advance!
GIPAPO
18 May 2022 09:12
First, remove all loose parts. Then, wrap the shelf carefully with blankets or bubble wrap. When carrying, support the joints firmly, preferably carry with two people. During transport, place the shelf upright in the vehicle and secure it with ratchet straps.
PLOMA
18 May 2022 10:05
Hello Mishel,
to address your concern in more detail: transporting an older BILLY bookshelf without its original packaging requires careful preparation. First, I would recommend removing all shelves and packing them separately. These are often the most fragile parts and can be easily damaged.
Next, you should thoroughly cushion the edges and surfaces of the bookshelf with thick furniture felt or blankets. It’s advisable to secure the padding loosely with tape to prevent slipping, but without sticking tape directly onto the bookshelf to avoid damaging the finish.
When carrying it: the bookshelf tends to wobble slightly in the middle under load. If carrying it with two people, the shoulders should be parallel along the long sides, paying special attention to the connection screws. If the screws are older, it would be beneficial to tighten them beforehand.
For transport, I recommend positioning the bookshelf as vertically as possible, as this reduces stress on the panels. Straps should be fastened to sturdy points but in a way that does not exert additional pressure on the panels. Various methods can help, such as placing an extra layer of padding between the bookshelf and the vehicle wall.
How long will the transport take and how maneuverable is the vehicle? This might influence the approach further.
Mishel
18 May 2022 11:29
PLOMA schrieb:
How long will the transport take, and how maneuverable is the vehicle?
Thanks for the detailed response! The drive takes about 30 minutes, and I will be using a simple van with plenty of space.
A follow-up question: Would you recommend taking the shelving unit completely apart or only partially (for example, removing the shelves)? Reassembling it at the destination is a bit inconvenient for me. The shelving unit is sturdy, but not brand new.
What do you think?
BAUEVA
18 May 2022 13:43
There are two sides to this: Completely disassembling the unit significantly reduces the risk of warping and damage at the joints, provided you carefully package all parts as described.
On the other hand, it increases the complexity and effort of reassembly—especially if the location at the destination is inconvenient.
Mishel schrieb:
Would you recommend taking the shelf apart completely or only partially (e.g., removing the shelves)?
For an older shelf showing signs of wear, I would recommend at least removing the shelves and checking all screws. If there aren’t too many connections, you could also remove the back panel; this makes transport safer and reduces the transport volume at the same time.
Also, please avoid tightening the screws too much to prevent damaging the material, as excessive torque can cause stress during subsequent transport.
cassandra
19 May 2022 07:16
The following points are helpful and scientifically supported:
1. Padding: Use at least 5 mm (0.2 inches) thick foam padding or several layers of furniture blankets to protect the surface from impacts and scratches.
2. Wrapping: Secure the padding with elastic tape that holds firmly under tension but leaves no residue.
3. Securing: Keep the shelf upright during transport, as a horizontal position places greater stress on the panels and increases the risk of breakage.
4. Ratchet Straps: Use ratchet straps to firmly secure the shelf to the vehicle without causing deformation.
5. Screws: Check that all screws are tight; loose connections increase the risk of movement and damage.
These tips are based on practical tests and recommendations, including those from IKEA itself.
If you remove the adjustable shelves, pack them separately, flat and well padded, to prevent breakage during transport.
