ᐅ Sound Insulation – Noise from the Bedroom
Created on: 13 Jan 2019 07:46
Mummy
We have a solid concrete block house made of aerated concrete (Ytong) and chose a wall thickness of 36cm (14 inches) between our bedroom and the children’s room instead of the originally planned 16cm (6 inches). Unfortunately, since our TV is placed directly against the wall to the children’s room, almost every word from the TV can be heard on the other side. We’re now hesitant to do anything else like watching TV in the bedroom to avoid disturbing the little ones.
What options for additional insulation between the rooms make sense here? So sticking egg cartons to the wall is out of the question. We have considered whether it would be sensible to install a drywall partition in front of the existing wall and insulate it with mineral wool to achieve the desired effect.
It might also be important to know that the entire floor on this level is installed continuously without gaps at the thresholds, and the ceiling above consists only of drywall, a vapor barrier foil, and a layer of insulation wool, with the open attic directly above that. Therefore, I’m not entirely sure whether the noise transfers mostly through the wall, over the floor, or through the ceiling and where the best place to start would be.
What do you think?
Thank you very much,
Martin
Mottenhausen
14 Jan 2019 14:51
A 36 cm (14 inch) interior wall should generally be fine. How is the TV mounted? Is the sound being transmitted through a wall mount to the wall, causing it to vibrate? There are decoupled wall mounts available for situations like this. Try testing by simply placing the TV normally in front of the wall; if there is no noise then, the wall mount is indeed the issue.
hanse987
14 Jan 2019 15:37
Why a 36cm (14 inch) wall? They only used a 16cm (6 inch) wall and are now having problems.
Wall mounting can of course be an issue and should definitely be checked out.
Caspar2020
14 Jan 2019 15:41
It’s a bit unclear... what exactly has been built now? 36 or 16?
hanse987
14 Jan 2019 16:00
Caspar2020 schrieb:
It’s written a bit confusingly.... so what exactly was built? 36 or 16?
You’re right! At first glance, I thought 16cm (6 inches) was used instead of 36cm (14 inches). After reading carefully, I’m not so sure anymore.
Z
Zaba12
14 Jan 2019 19:58
Oh, how wonderfully intuitive everything was done correctly! The children's rooms are in the west wing and the master bedroom in the east wing :-p
Theodorius
14 Jan 2019 20:48
I made it even better: I didn’t plan a nursery at all.
