ᐅ Electrical outlet always loose on tiled wall. How to fix it?
Created on: 12 Mar 2019 10:15
KeishadowK
Keishadow22 Mar 2019 19:58Knöpfchen schrieb:
There are plaster leveling rings for that Cool, I didn’t know that. Thanks for the info! Unfortunately, I’ve already repaired it with plaster. If it comes off again, I will fix it using those. Thx
Hello
Köpfchen gave the right advice: use spacer rings on the blank wall box. Naturally, screw the spacer rings onto the blank wall box. If you want to do a good job, fill the gap between the plaster and the spacer ring with filler. Then screw the outlet into the spacer rings with appropriate screws. And if you tighten the retaining clips a bit, it should last until the next Stone Age.
Steven
Steven
