ᐅ Single-family house with a gable roof, approximately 137 sqm (about 1,474 sq ft), one full story
Created on: 13 Apr 2020 12:41
Revendare
Hello dear forum community,
we are well advanced in planning our single-family home with a gable roof and have already decided on a construction company. Unfortunately, we are not yet 100% satisfied with the current floor plan. Therefore, we are now turning to you for advice.
Building Plan/Restrictions
Plot size: 1,010 sqm (1,010,000 sq ft approx.)
Slope: slightly rising, approximately 1.8 m (6 ft) from the house location to the end of the plot
Site coverage ratio: No building plan, plot has 20 m (65 ft) frontage
Building window, building line and boundary
Setback from property line: 3 m (10 ft)
Number of parking spaces: 2 cars in double carport, 1-2 in front of the house (street parking inconvenient)
Number of floors: 1.5
Roof type
Architectural style
Orientation: North-facing garden
Maximum heights/restrictions
Additional requirements: Neighbor is the plot seller and has several conditions, including house height (not higher than theirs), and the carport must be on the boundary with the other neighbor
Homeowners’ Requirements
Architectural style, roof type, building type: single-family home, gable roof, not too modern
Basement, number of floors: no basement, 1.5 floors
Number of occupants, age: currently 2, both around 30, planning for 2 children
Space requirements on ground floor: living/dining/kitchen, utility room, office, guest WC with shower, storage room behind carport as basement substitute
Space requirements on upper floor: 2 children’s rooms, master bedroom, bathroom, possibly storage room
Office use: family or home office? home office
Number of overnight guests per year: negligible
Open or closed layout: open
Traditional or modern construction style: rather traditional
Open kitchen, kitchen island: open yes, possibly kitchen island, currently a G-shape is planned
Number of dining seats: 6
Fireplace: undecided, leaning towards yes
Music/stereo wall: no
Garage, carport: double carport
Kitchen garden, greenhouse: not planned
Other wishes/features/daily routine, also reasons why some things should or should not be included
Planner: partner architect of the construction company
What do you like most? Why? open living-dining area with lots of glass and views into the large garden, dormer at front greatly enhances the house and should flood it with light, current room layout
What do you dislike? Why? straight staircase and resulting long hallway both on ground and upper floor. Unfortunately, the architect insists that with this house width another staircase design is hardly possible without removing the office.
Estimated price according to architect/planner: €360,000 including incidental building costs, technical systems, etc., but excluding kitchen
Personal price limit for house including fittings: €380,000
Preferred heating system: ground-source heat pump
If you had to give up on some details/extras
-that you could do without: fireplace, straight staircase
-that you could not give up: office, basement substitute
Why has the design ended up as it is now? The architect tried to meet our desired room program and the neighbor’s restrictions
Which wishes were implemented by the architect? door from carport to utility room, office, shower in guest WC, open living-dining area with lots of glass
What do you consider especially good or bad about it? In my opinion, the straight single-flight staircase takes up a lot of space; the requirement from the plot seller (neighbor to east side) makes natural light inside difficult — hence the dormer with open hallway in the living-dining area to bring more light into the house
I am now hoping for some suggestions on how we could get more out of the current floor plan while keeping the same room layout. I assume the simplest way would be a different staircase design.
Please excuse me if I have not filled out all questions correctly for the floor plan discussion.
Revendare
Roof type
Architectural style
Revendare
Revendare schrieb:
Basically a good suggestion. However, as mentioned, it will probably be more expensive if we move the carport forward. Then more excavation would be required, and it would need to be supported with a strip foundation. I don’t quite follow. If you don’t move it forward, you still have to excavate the same amount. Or do you have a building plot where one level already exists? Does the slope of the hill change that significantly?
Revendare schrieb:
Also, we actually liked how the living room is oriented towards the garden. Then swap the living room with the kitchen.
Revendare schrieb:
Maybe we could plan a different staircase so we can explore further? First, place the house and outbuildings. Then refine the floor plan.
Revendare13 Apr 2020 16:37Ok, got it.
Let’s note this down. I also added the bathroom with shower. The area with the “boxes” could then become the terrace.
The side view illustrates it quite well. The dashed line shows the original situation. Edit: that was confusing, please ignore that^^
kaho674 schrieb:
I don’t quite follow. If you don’t move it forward, don’t you have to excavate just as much? Or do you have a building plot that already has a level area? Does the slope of the hill change that much?
So, I would suggest working with the height, since you will have to adapt to the slope somehow.
Slightly cutting into the ground for the carport and adding two steps up to the front door... something like that.
And where you have marked the WC, the new space-saving staircase should actually go there. The WC can be arranged elsewhere.
On the upper floor, of course, the bathroom should be directly above, with the children's room getting natural sunlight.
Revendare13 Apr 2020 16:52ypg schrieb:
So, I would suggest adjusting the height since you’ll have to accommodate the slope somehow. Maybe excavate a bit for the carport and have two steps up to the front door… something along those lines. We had considered something like that at the beginning. However, since the carport would then be lower than the house, we chose the simplest and most cost-effective option to keep the carport at the same level as the house.
We’ll bring this up again with the architect.
And where you marked the WC, the new space-saving staircase should actually go there. The WC can be arranged accordingly. On the upper floor, directly above that would be the bathroom and the children’s room with natural light. Okay, I’m not sure about the staircase—I don’t really know how exactly it should fit there^^
I thought it has to be placed lengthwise in the house?
Something like this:
Revendare schrieb:
should she register here in the forum so she can join the discussion xDYou can quickly slide the laptop over to your significant otherhttps://www.instagram.com/11antgmxde/
Revendare13 Apr 2020 16:5811ant schrieb:
You can quickly slide the laptop over to your loved one My loved one is sitting next to me, reading along :PSimilar topics
