ᐅ Single-family house with a gable roof, approximately 137 sqm (about 1,474 sq ft), one full story
Created on: 13 Apr 2020 12:41
Revendare
Hello dear forum community,
we are well advanced in planning our single-family home with a gable roof and have already decided on a construction company. Unfortunately, we are not yet 100% satisfied with the current floor plan. Therefore, we are now turning to you for advice.
Building Plan/Restrictions
Plot size: 1,010 sqm (1,010,000 sq ft approx.)
Slope: slightly rising, approximately 1.8 m (6 ft) from the house location to the end of the plot
Site coverage ratio: No building plan, plot has 20 m (65 ft) frontage
Building window, building line and boundary
Setback from property line: 3 m (10 ft)
Number of parking spaces: 2 cars in double carport, 1-2 in front of the house (street parking inconvenient)
Number of floors: 1.5
Roof type
Architectural style
Orientation: North-facing garden
Maximum heights/restrictions
Additional requirements: Neighbor is the plot seller and has several conditions, including house height (not higher than theirs), and the carport must be on the boundary with the other neighbor
Homeowners’ Requirements
Architectural style, roof type, building type: single-family home, gable roof, not too modern
Basement, number of floors: no basement, 1.5 floors
Number of occupants, age: currently 2, both around 30, planning for 2 children
Space requirements on ground floor: living/dining/kitchen, utility room, office, guest WC with shower, storage room behind carport as basement substitute
Space requirements on upper floor: 2 children’s rooms, master bedroom, bathroom, possibly storage room
Office use: family or home office? home office
Number of overnight guests per year: negligible
Open or closed layout: open
Traditional or modern construction style: rather traditional
Open kitchen, kitchen island: open yes, possibly kitchen island, currently a G-shape is planned
Number of dining seats: 6
Fireplace: undecided, leaning towards yes
Music/stereo wall: no
Garage, carport: double carport
Kitchen garden, greenhouse: not planned
Other wishes/features/daily routine, also reasons why some things should or should not be included
Planner: partner architect of the construction company
What do you like most? Why? open living-dining area with lots of glass and views into the large garden, dormer at front greatly enhances the house and should flood it with light, current room layout
What do you dislike? Why? straight staircase and resulting long hallway both on ground and upper floor. Unfortunately, the architect insists that with this house width another staircase design is hardly possible without removing the office.
Estimated price according to architect/planner: €360,000 including incidental building costs, technical systems, etc., but excluding kitchen
Personal price limit for house including fittings: €380,000
Preferred heating system: ground-source heat pump
If you had to give up on some details/extras
-that you could do without: fireplace, straight staircase
-that you could not give up: office, basement substitute
Why has the design ended up as it is now? The architect tried to meet our desired room program and the neighbor’s restrictions
Which wishes were implemented by the architect? door from carport to utility room, office, shower in guest WC, open living-dining area with lots of glass
What do you consider especially good or bad about it? In my opinion, the straight single-flight staircase takes up a lot of space; the requirement from the plot seller (neighbor to east side) makes natural light inside difficult — hence the dormer with open hallway in the living-dining area to bring more light into the house
I am now hoping for some suggestions on how we could get more out of the current floor plan while keeping the same room layout. I assume the simplest way would be a different staircase design.
Please excuse me if I have not filled out all questions correctly for the floor plan discussion.
Revendare
Grundriss: Garage, Abstellraum, Flur, WC, Arbeitszimmer, Essen/Wohnen/Küche (43.34 m²)
Grundriss des Obergeschosses: Schlafzimmer, zwei Kinderzimmer, Bad, Flur und Treppe; Norden oben.
Kadastrale Karte: rotes Baugrundstück mit umliegenden Parzellen und Nordpfeil oben.
Frontansicht eines modernen Hauses mit Garage, Baum links, Person am Eingang, Grundstücksgrenze.
Linke Seitenansicht eines Hauses auf Hang mit Person am Eingang neben Carport.
Rückansicht eines Hauses: Dach, drei Fenster, Tür, Mensch als Maßstab, Grundgrenze.
Schnittansicht eines Einfamilienhauses mit Rohbau, Fundamenten und Innenwänden im Maßstab 1:100
Revendare
13 Apr 2020 18:58
Where would you like to have the spiral staircase?
We had imagined it something like how ypg did it in post #42
The single-flight straight staircase planned here only works if you accept needing a bay projection.
Exactly – maybe we could skip that and save a few thousand euros.
11ant13 Apr 2020 19:03
A two-digit thousand.
Revendare
13 Apr 2020 19:03
So, before I stop here, I’m posting the abandoned attempt.
To explain: Trying to move the open-plan area more toward the southwest, so it was countered. (Considering the view into the garden from the living room)
Several attempts to change the staircase: failed
Instead: changed the staircase layout to create more privacy in the living area (growing children coming home)
Wardrobe possibly under the stairs or separated from the utility room.
I would like the utility room at the back, but it doesn’t work without losing floor area.
Maybe I’m stuck.
@kaho674 @kbt09 @RomeoZwo maybe you have a constructive idea?! I give up [ATTACH alt="Bildschirmfoto 2020-04-13 um 18.40.49.png"]45295[/ATTACH]
Thank you for the effort to work this out.
We like the approach with the staircase, as it probably also creates better possibilities upstairs.
kaho67413 Apr 2020 19:12
Basic tip: don’t start working on it late in the afternoon. By evening, the necessary mental energy is used up.
13 Apr 2020 19:15
kaho674 schrieb:
Basic tip: don’t start working on projects late in the afternoon. By evening, the necessary mental energy is used up.
That might work for you – I reach my peak performance at 1 a.m.
kaho67413 Apr 2020 19:21
I reach my peak form at 1 a.m.
In what way?
