ᐅ Safely Mounting Ikea Metod Wall Cabinets on Different Wall Types
Created on: 21 May 2021 18:27
Maiapra
Maiapra
21 May 2021 18:27
I am planning to install several IKEA Metod wall cabinets in my kitchen. Now I am wondering how to securely fix them to different types of walls. At my home, there is a combination of concrete walls in the kitchen area and drywall (plasterboard) walls in the adjacent dining room, where I also want to mount cabinets.
My main concern is secure mounting:
- What kind of anchors or fasteners are best suited for concrete walls?
- What about drywall (plasterboard) walls to ensure the wall cabinets hold permanently and there is no risk of them coming loose?
- Are there specific techniques or tips for distributing the load most effectively?
I am also interested in whether there are special mounting frames or accessories from IKEA recommended to stabilize the installations, or if it is better to rely on third-party products.
I look forward to any tips, experiences, or reliable recommendations on how to safely mount Metod wall cabinets on various types of walls.
SUBEN60
21 May 2021 19:14
For concrete walls, I recommend heavy-duty metal anchors, such as expansion anchors or bolt anchors, as they ensure high load-bearing capacity. It is important to use anchors with a minimum diameter of 8 mm (0.3 inches) and to thoroughly clean out the drill holes from dust.
For drywall (plasterboard) walls, the situation is much more delicate: only special cavity anchors or toggle bolts can be used. The load capacity depends on the thickness of the panels and the material behind them.
The weight of wall cabinets (usually around 20-30 kg (44-66 lbs) per cabinet, without contents) makes it essential to use an additional wooden batten or a mounting frame fixed to a load-bearing wall surface or the ceiling to better distribute the load on drywall.
IKEA itself does not offer a special mounting frame; in this case, third-party products or custom-made substructures are recommended.
As a general rule, I advise always checking the wall construction first (using an electrical or material scanner) and thoroughly inspecting the area intended for the anchors before starting installation.
BAUEVA
22 May 2021 08:32
SUBEN60 schrieb:
The situation is much more sensitive with drywall partitions: only special cavity anchors or toggle bolts can be used here.
I agree with that, but I would like to add that the quality of the anchors also matters. Cheap cavity anchors often fail, especially under dynamic loads such as the opening and closing of cabinets.
In addition, using a reinforcement with a sturdy wooden batten or, better yet, a metal strip is recommended. This should be attached at load-bearing points, ideally over at least two to three wall fixing points.
Does Ikea offer accessories for this? I am not aware of any, which is why a custom-made wood or metal support is advisable.
One more note on load distribution: if you hang several cabinets side by side, it makes sense to mechanically connect them horizontally as well, in order to distribute the load across multiple mounting points simultaneously.
A simple, off-the-shelf installation is not sufficient for different wall types, because the combination of concrete and drywall requires different fastening methods, as mentioned, with an adequate safety margin.
dunitan
22 May 2021 09:45
I am happy to provide some detailed tips on the topic:
Regarding concrete walls: It is important not only to use anchors suitable for the load but also to inspect the substrate for cracks or porous areas that could make fastening difficult. With solid concrete, this is usually not an issue, but with older concrete ceilings, you should use an appropriate drill bit and potentially injection mortar techniques to optimize the anchoring.
Regarding drywall (plasterboard) walls: Since drywall panels alone do not have sufficient load-bearing capacity, I generally recommend always attaching fixtures to the underlying wood or metal studs. A stud finder can be used for this purpose.
If this is not possible, metal anchors (such as metal toggle bolts) provide better load-bearing capacity than simple plastic hollow wall anchors. Installing an additional mounting frame made of wood can help distribute the load across multiple points and significantly reduce the risk of damage.
On the topic of IKEA accessories: There are actually no specialized mounting systems at IKEA for different wall types. Therefore, it is advisable to supplement with professional-grade mounting materials available at hardware stores.
In conclusion: Safety comes first, especially when it comes to wall cabinets. I would recommend investing a little more time in preparation and installation to ensure that the cabinets last for decades.
BAUEVA
23 May 2021 07:38
dunitan schrieb:
If that is not possible, metal anchors (such as metal toggle bolts) provide better load capacity than simple plastic hollow wall anchors.
This is a very important point, especially for kitchen cabinets that are frequently opened and closed during daily use.
I would also recommend, for drywall partitions, using a combination of a wooden batten attached to the wall along with metal toggle bolts to significantly reduce the forces involved.
Additionally, a tip for Maiapra: arranging the cabinets during installation so that as many fixing points as possible align with solid wall sections, meaning drywall areas with studs behind them, greatly increases stability.
Does anyone here have experience using injection mortar in concrete for these cabinet installations? I have heard that it improves load-bearing capacity and reduces vibrations.
That would be particularly interesting for older walls.
Maiapra
23 May 2021 12:10
BAUEVA schrieb:
Does anyone have experience using injection mortar in concrete for these cabinet installations?
Thanks for the tip. I haven’t used injection mortar before, but it sounds very interesting, especially for areas with concrete walls. Can it also be used on older concrete walls in older buildings that seem somewhat porous?
Regarding drywall: I will definitely use a stud finder and try to distribute the load as evenly as possible across multiple points when mounting. Your advice on combining wooden battens with metal toggle anchors is very helpful.
Do you have any practical and secure tips for achieving horizontal stabilization between multiple cabinets? I read that some use connectors from the mailbox cabinet area, but I’m not sure if that holds reliably.
Thanks to everyone for the detailed and professionally informed contributions so far.
