ᐅ Securely Installing Ikea Metod Kickboards for a Stable and Visually Perfect Fit
Created on: 26 Sep 2023 18:37
palko40Hello everyone,
I am currently facing the challenge of securely mounting the baseboards of my Ikea Metod kitchen system and aligning them neatly with the cabinet carcasses. The problem I have is twofold: first, the usual included clips and screws feel too unstable and are sometimes difficult to install perfectly straight. Second, I want to avoid the baseboards sitting crooked or leaving unattractive gaps between them and the cabinet carcasses, which is especially problematic on uneven floors.
Does anyone have tips or proven methods for fastening Metod baseboards firmly without compromising the appearance? Are there alternative mounting systems or tricks to improve the fit, especially when the floor or cabinet edges are not perfectly straight?
I look forward to your experiences and advice!
The Ikea Metod plinths are basically designed to be attached with clips to the frames of the kitchen cabinets. If you find the stability insufficient, I recommend first checking whether the clips are properly snapped in and not damaged or too loose.
For a more secure installation, there are some proven methods:
- Using additional furniture brackets or small screws to fix the plinths inside the cabinet frame.
- Lightly sanding the clamping surfaces if the clips do not hold well.
- Metal mounting rails or profiles can be used to compensate for uneven floors.
For the visual adjustment, make sure the plinths are cut to size before final installation, ideally with a miter saw for clean edges. It is also advisable to perform a dry fit before mounting to identify fitting issues and possible gaps early on.
Joshbe schrieb:
For a more stable installation, there are some proven methods:This is a good approach, but in the long term, I do wonder whether it makes sense to stick to a system that apparently only works really well with additional components.
Are there any studies or long-term experiences showing that alternative fastening methods, such as screwing the trim strips, do not cause damage to the kitchen structure? I know of cases where incorrect screws caused materials to split or made later removals more difficult.
Perhaps it’s also worth considering other baseboard systems specifically designed for uneven floors instead of sticking to the original clips, whose functionality seems to be limited according to real-world tests. Who has reliable experience with this?
theo63 schrieb:
Maybe it’s worth taking a look at other baseboard systems that are specifically designed for uneven floorsI can understand that the original clips can sometimes be frustrating, especially when you put a lot of effort in but get stuck on the details. I felt the same way and started wondering if the whole system was really suitable for my kitchen.
My advice: before making major modifications, take the time to prepare thoroughly. For example, I cut small wooden wedges to level the floor. This allowed the baseboards to be fastened much more securely without being crooked or wobbly.
You can tell these adjustments take some time, but the effort is worth it because in the end you get a result you can be proud of.
[quote=Joshbe, post: s0g4k4, member: XXX]For a more secure installation, there are some proven methods:
- Using additional furniture brackets or small screws to fix the baseboards inside the cabinet frame.
- Lightly sanding the clamping surfaces if the clips don’t hold well.
- Mounting rails or metal profiles can be used as spacers on uneven floors.
When adjusting the appearance, make sure the baseboards are cut to size before the final installation, ideally with a miter saw for clean edges.
Thanks for the clear tips! I’m surprised that Ikea doesn’t address these challenges better, especially the issue with uneven floors, which I’ve heard mentioned as a frequent weak point.
Could you explain a bit more about the “mounting rails or metal profiles”? I’m not quite sure how this is implemented in practice, especially in combination with baseboards that are supposed to lie flat.
One more question about the visual adjustment: How exactly can I avoid visible gaps between the baseboard and the cabinet? Should silicone be used here, or are there more elegant solutions?
