ᐅ Overhanging Edges on KALLAX – How to Fix the Appearance?
Created on: 7 Jan 2020 19:04
kimru
I am currently dealing with a rather specific issue with the IKEA KALLAX shelving unit: the edges of the shelves stick out by about 2-3 mm (0.08-0.12 inches), which unfortunately affects the overall appearance. It doesn’t look neat or professionally assembled, even though everything was put together correctly.
Has anyone here experienced overhanging edges with KALLAX shelves? I am wondering what the best way to improve the look is without removing the shelves or buying expensive accessories. Are there any handy tips or craft techniques to conceal or make the overhang look more appealing?
I would really appreciate any practical advice or even professional solutions.
Thanks in advance!
kimru
8 Jan 2020 17:15
nubar schrieb:
Use wood filler – a white acrylic wood filler is ideal for leveling small depressions or waves.
Thanks for the tip about the filler; it will definitely save me some frustration when making adjustments.
Palenar schrieb:
Perfection is in the details 🙂
I agree with that!
So tomorrow I’m planning to do a workshop on sanding, filling, and gluing, and then test on a hidden corner. The goal is to achieve an almost invisible edge without making major changes to the shelf.
I’ll report back here once I have some initial results; maybe it will help others facing a similar issue.
Thanks for the great exchange so far!
PERON
9 Jan 2020 08:32
Hey kimru and everyone!
Great discussion here. I really like how carefully you’re approaching the edges – the details really make the difference!
If I may add a bit of flair: a slight color variation can look really cool as a design feature. Especially with white shelves, a bit of contrast on the edges isn’t distracting but adds visual interest.
Of course, if you want a completely neutral look, that’s not the way to go. But sometimes a small risk is worth it for the appearance. And hey, with a few color samples on leftover wood, you can quickly see what works! 🙂
Keep it up!
kimru
9 Jan 2020 13:15
PERON schrieb:
A subtle shade with a slight variation can also look really cool as a design feature.
Thank you for the creative idea! I actually considered briefly whether a subtle gray tone along the edge might complement the white well.
However, that would definitely be a second step after trying to preserve the original as closely as possible.
First, I will try sanding, filling, and gluing. If I’m not satisfied with the smooth edge, I’ll test your idea with color.
Thanks for the suggestion – sometimes ideas like this really help to move beyond purely functional thinking! 🙂
Glage
9 Jan 2020 15:07
I really appreciate how you’re all working together here and going into such detail.
I once had a similar issue with another IKEA shelving unit myself and know how frustrating that can be.
Just a little encouragement: It’s definitely worth taking it step by step and avoiding overworking the edges – otherwise, you can quickly feel overwhelmed.
And if something does go wrong: The shelf won’t cause any problems, the KALLAX base is sturdy, and often small irregularities are less noticeable in everyday use than you might think.
So don’t be too hard on yourself; that’s also a skill when doing DIY projects 😉
Good luck!
kimru
9 Jan 2020 19:46
Glage schrieb:
And if something goes wrong: the shelf doesn’t cause wars, the KALLAX base is sturdy,
I really take that to heart, thank you!
Sometimes, when following YouTube tutorials or professional guides, you can be so hard on yourself that you forget a shelf is simply a piece of furniture meant primarily to be functional.
Still, I want to do it as well as possible, and your tips give me the necessary know-how for that. I will start with the first test tomorrow and look forward to updating you.
Have a great evening, everyone!
