ᐅ Upgrading KALLAX with Dust Protection – Are Dust Seals from the DIY Store Effective?
Created on: 5 Jan 2020 08:17
naonur
I own a Kallax shelving unit from IKEA, which I mainly use to store items I want to protect from dust. Unfortunately, I have noticed that the open shelves are not really dustproof, which becomes annoying over time. Now I am considering how to best retrofit the Kallax unit with dust seals, ideally without major structural modifications or expensive special solutions.
My specific question is:
Are there practical and cost-effective ways to add dust protection or dust seals to the Kallax shelving unit, for example using standard seals from a hardware store? If so, which materials work best, how can they be applied, and what are your experiences with such solutions—especially regarding durability, appearance, and ease of use?
I look forward to your tips and opinions!
theota
6 Jan 2020 09:23
praWarre69 schrieb:
Funny enough, they almost look like professional rubber seals
Of course, if you just cut and stick everything together carelessly, it tends to look more like a makeshift craft project. The KALLAX is a stylish piece of furniture – so you should choose matching solutions. I find those hardware store seals cheap and visually unappealing.
GiRoyce schrieb:
By the way, praWarre69’s tip about the fabric curtain is also brilliant
Fabric curtains are by far the better option, since seals can cause problems from time to time: warping, poor adhesion, and dust still settling on the seals.
I would recommend custom-made plexiglass or acrylic doors instead as a perfect dust barrier. Sure, they are more expensive, but then the shelf is truly dustproof, looks neat, and lasts a long time. Not every cheap solution is a good one.
naonur
6 Jan 2020 13:55
theota schrieb:
I lean more towards custom-made plexiglass or acrylic doors as an ideal dust barrier.
That’s an interesting point of view. However, I prefer not to make major modifications to the KALLAX and instead want to retrofit it with as little effort as possible.
GiRoyce schrieb:
I can also recommend paying attention to sealing types with strong adhesion, possibly those with silicone adhesive.
Could you please explain that in more detail? Which seals exactly are you referring to, and where can they be found?
Also, I would appreciate if anyone has experience regarding how airtight these solutions really are. I’m concerned that dust will not be effectively kept out if the seal isn’t perfectly fitted.
LUSAR
6 Jan 2020 17:11
Additional Information:
1. The commonly available self-adhesive foam rubber seals at hardware stores are usually between 2 and 5 mm (0.08 and 0.2 inches) thick. They provide sufficient dust sealing for KALLAX shelves, as long as they are applied correctly.
2. Important: The surface must be thoroughly cleaned and degreased before applying to ensure the adhesive holds permanently.
3. Alternatively, felt strips can also be used, but they wear out faster and provide less sealing.
4. For dust protection, a combination of doors and seals is usually advisable. If the shelf does not have doors, appropriate doors can be purchased or custom-made.
5. Dust protection largely depends on the accuracy of the sealing. Complete dust tightness cannot be guaranteed with simple hardware store seals.
6. Plexiglass doors definitely offer better protection, but require craftsmanship skills and increase costs.
In summary: Hardware store seals are a practical and affordable solution that significantly reduces dust ingress but do not replace complete sealing.
Katau
6 Jan 2020 20:39
LUSAR schrieb:
Hardware store seals are a practical and affordable solution that noticeably reduce dust entry
I can confirm that. I personally used foam rubber seals from the hardware store to upgrade my KALLAX shelving unit. The seals are easy to install neatly; you just need to allow enough time for proper adjustment. For my needs, this is perfectly sufficient for household use.
One tip: when purchasing, make sure the seal isn’t too wide, or the doors might get stuck. Sometimes lightly sanding the edges of the doors helps them close better.
So, if you don’t want to go all out, good hardware store seals are a reliable middle-ground solution.
