ᐅ Upgrading KALLAX with Dust Protection – Are Dust Seals from the DIY Store Effective?
Created on: 5 Jan 2020 08:17
naonur
naonur
5 Jan 2020 08:17
I own a Kallax shelving unit from IKEA, which I mainly use to store items I want to protect from dust. Unfortunately, I have noticed that the open shelves are not really dustproof, which becomes annoying over time. Now I am considering how to best retrofit the Kallax unit with dust seals, ideally without major structural modifications or expensive special solutions.
My specific question is:
Are there practical and cost-effective ways to add dust protection or dust seals to the Kallax shelving unit, for example using standard seals from a hardware store? If so, which materials work best, how can they be applied, and what are your experiences with such solutions—especially regarding durability, appearance, and ease of use?
I look forward to your tips and opinions!
praWarre69
5 Jan 2020 08:45
Hey naonur,
I think the idea of making KALLAX dustproof is really practical; I feel the same way! 🙂 Hardware store seals are definitely an option—for example, self-adhesive foam rubber strips or foam profiles work quite well. It’s important to apply the seals cleanly and evenly along the edges so the doors close better and dust has less chance to get in.
Interestingly, if done neatly, they can even look almost like professional rubber seals. The only downside is that you might need to replace the seals after a few months because they can deform slightly or collect dust. But they don’t cost much anyway 😉
What I would also do: add doors or fabric curtains as extra dust protection, which you can easily attach with hook-and-loop tape.
tarju41
5 Jan 2020 09:11
Simply look for self-adhesive foam rubber seals at your local hardware store and attach them to the edges of the KALLAX doors or compartments. This will significantly reduce dust entering.
SUDAN
5 Jan 2020 12:24
Hello!
Here is a brief guide on how to effectively implement dust protection on the KALLAX shelf unit using hardware store seals:
1. Seal selection:
- Sponge rubber seals: flexible, easy to stick on, provide good sealing
- Foam profiles: more affordable, more versatile, but less durable
2. Preparation:
- Clean surfaces, lightly degrease
- Take measurements, cut to size
3. Installation:
- Gradually apply the seal, press firmly
- Check door fit afterwards, adjust if necessary
4. Tips:
- For particularly fine dust, doors with magnetic closures are also recommended
- Check and clean seals occasionally to prevent dust buildup
Be cautious with cheap adhesives – they may leave residues or cause the seal to come loose. Also, ensure the adhesive is moisture-resistant if used in humid environments.
Summary: Seals from the hardware store are quite suitable, especially sponge rubber ones. Proper application and regular inspection are essential.
barsar
5 Jan 2020 17:02
Foam rubber from a hardware store works well; simply clean it with a cleaner to remove dust, apply adhesive, and it should hold. It usually lasts for several months. For better dust protection, magnetic strips can also be used.
GiRoyce
5 Jan 2020 20:48
Hello naonur,
I added weatherstripping to my own KALLAX shelf because I wanted to keep dust out as much as possible. In my experience, self-adhesive foam tape on the doors provides a solid seal while being barely noticeable visually.
By the way, the tip from praWarre69 to use a fabric curtain is also brilliant, especially if you store larger items or loose things on the shelf. Using Velcro strips or slim curtain rods, you can easily create a dust barrier in a creative way.
What was important to me: not to choose sealing material that is too thick, as the doors might not close properly otherwise. And if you use the shelf regularly, it’s worth checking the weatherstripping every six months or so.
If you want, I can also recommend choosing sealing types with good adhesive properties, possibly those with silicone-based glue. These often hold better than standard adhesives.
Good luck!
