ᐅ Upgrading Ikea Metod Cabinet Doors with Soft-Close Mechanism for Smooth and Durable Operation
Created on: 29 Dec 2021 17:42
Marcel67
Marcel67
29 Dec 2021 17:42
I am planning to retrofit soft-close functionality to the existing doors of my Ikea Metod kitchen because gentle closing is very important to me to reduce noise and extend the lifespan of the hinges. I am primarily looking for a solution that not only works smoothly but is also durable and compatible with Metod doors without having to replace the entire door mechanism.
Has anyone had experience with retrofit kits or specific soft-close hinges for Ikea Metod doors? Which products have proven reliable, and are there any installation tips to ensure everything closes softly and maintains durability?
I would appreciate your answers and advice on the best way to achieve this!
KAMERON
29 Dec 2021 18:09
Hello Marcel67,
In principle, it is possible to retrofit the soft-close function on Metod doors. Ikea itself offers hinges with integrated soft-close functionality for Metod kitchens, but for retrofit solutions from third-party manufacturers, there are mainly two options:
- Replacing the existing hinges with soft-close hinge models that fit the mounting profile.
- Retrofit dampers that are additionally attached to the doors to make closing smoother.
It is important for both options to consider the correct sizing and compatibility with the Metod door and cabinet system, as not all soft-close components fit universally. A common mistake is the lack of proper mounting points, which complicates or reduces the reliability of installation.
Therefore, I recommend ordering the appropriate hinges directly from Ikea, as these fit the system exactly. Alternatively, products from BLUM or Hettich are often compatible and offer soft-close hinges. Make sure the hinges are marked as soft-close and have the same drilling pattern.
Installation requires precise alignment of the hinges to ensure even, smooth closing. A spirit level and a drill template set can be helpful, especially if old holes need to be enlarged.
The durability of the soft-close function depends greatly on the materials used and the quality of the dampers. High-quality branded products last several years and withstand mechanical stress without problems.
In summary:
- Best to replace existing hinges with soft-close models
- Retrofit dampers are available but less proven for long-term use
- Pay attention to compatibility with Metod
- Careful installation is crucial for proper function
If you want, I can also provide more specific product names.
Will44
29 Dec 2021 19:31
I agree – those really make a difference! Just think about how often you open and close your kitchen cabinet doors every day. You definitely don’t want any banging or noises that get annoying over time.
Shortly after moving in, I swapped the hinges on my Metod kitchen from Ikea with their soft-close version. It took about 30 minutes, and the result is fantastic: the doors now close so smoothly, it almost feels like they close by themselves.
A little tip: mark the positions carefully beforehand and don’t overtighten the screws – you can quickly feel if the mechanism isn’t working properly.
Of course, it’s not the cheapest upgrade, but you really notice the added value—especially if you have kids who sometimes slam the doors a bit louder.
If you’re interested, I can also share a short DIY report sometime.
V
Victor54
30 Dec 2021 09:14
Will44 schrieb:
I agree – those things really make a difference!
I would like to raise a small objection. While original soft-close hinges from Ikea may seem like an easy solution at first glance, is it really worthwhile in every case?
I have read that especially in heavily used kitchens and doors with frequent opening and closing, external dampers can sometimes wear out faster than durable direct hinges designed specifically for heavy long-term use.
Additionally, the question of how door weight affects performance is often overlooked. A lightweight door can be closed gently without issue, but with large fronts made of heavier materials, simple retrofit dampers might reach their limits.
From my point of view, it’s important to carefully check the door dimensions and materials first before blindly relying on a retrofit soft-close solution. Otherwise, there is a risk that the new mechanism will wear out quickly or not function properly.
In summary, I would recommend looking for reliable systems that account for both functionality and long-term load capacity as well as door weight.
RON57
1 Jan 2022 22:07
Victor54 schrieb:
From my perspective, you should first carefully check the door dimensions and material before blindly opting for an aftermarket soft-close solution.
This assessment is very important, especially for Metod kitchens. About six months ago, I retrofitted several Metod doors and can add the following practical tips:
- Measuring the doors, including thickness and weight, is essential to select appropriate hinges or dampers.
- For very thin doors (e.g., with white foil covering), it is better to replace them with original soft-close hinges from Ikea’s range, as they have the correct built-in damping.
- External soft-close dampers can usually be installed by yourself, but they tend to be more noticeable and are easier to damage if placed incorrectly.
- The so-called “long hinge” version (a large hinge with built-in damper) is generally more durable and reliable than individual retrofit dampers.
Regarding durability: I installed hinges from BLUM that were described as compatible with Metod. In my view, the precision manufacturing and the quality of the dampers make the difference—they have proven to be very robust in tests.
If desired, I can provide a list of compatible products and suppliers upon request.
