ᐅ Is it possible to replace existing doors in a Billy shelf unit with softer ones?
Created on: 10 Nov 2015 14:03
FUTISON
I am considering replacing the existing doors on my Billy bookshelf with softer, meaning more gently closing doors. Specifically, I want to know if this is technically possible without much effort or having to make adjustments to the hinges or door size. My goal is to achieve a smoother, softer closing motion so that the doors don’t slam and perhaps close more quietly. Does anyone have experience with this or tips on what to pay attention to? I’m unsure about what alternatives for doors are available and whether dimensions or material thickness play a role. Thanks in advance!
Morgan
11 Nov 2015 11:37
I understand the desire for softer-closing doors well; it simply feels more premium and pleasant in daily use. Have you ever considered retrofitting door dampers, like the ones IKEA offers (these are small dampers installed inside the door)? This way, nothing will slam shut anymore without having to replace the doors. Just as an interim solution if a full replacement seems too time-consuming.
TEBILO
11 Nov 2015 12:15
pinbo schrieb:
The soft-close mechanism is usually mounted separately on the hinge.
Exactly. For those who want to dive deeper:
When building or buying new doors, you need to pay attention to the so-called 3D adjustment of the hinges – meaning you can adjust height, depth, and lateral position. This makes fitting the doors much easier. Cheap doors or doors not designed for the frame system (like Billy) often lack these drillings, which makes later installation very difficult.
And another thing: if you use significantly thicker doors, the hinge’s mounting position must also be correct. Otherwise, the doors won’t close flush or may warp slightly. Therefore, it’s important to consider hinges and doors as a system, not as separate parts.
FUTISON
12 Nov 2015 09:05
Okay, I’ve learned a lot! I will start by testing the soft-close hinges – they seem the most practical. If I decide to get new doors later, I will pay attention to the drilling hole positions.
Thanks to everyone who replied so thoroughly and helpfully! 🙂 I’ll get back to you once I have a plan or have gathered some experience.
