ᐅ Replacing Billy Regal edge banding – practical tips.
Created on: 16 Dec 2021 19:33
MOKEO
MOKEO
16 Dec 2021 19:33
I noticed that the edge of one of the shelves in my Billy bookcase is quite badly damaged – chipped in places and frayed. I want to renew the edge, but I don’t want to just use the usual edge banding because the shelves are made of laminated melamine, and I’m concerned that the new edge band might not adhere properly or could come loose after a short time.
Does anyone have practical tips or experience on the best way to restore the edge to make it as durable as possible?
I’m also considering whether I should go for some kind of sanding and sealing method or stick with applying heat-activated edge banding. Perhaps there are also alternatives like liquid edge solutions or similar?
Looking forward to your recommendations!
nojaus
16 Dec 2021 20:14
Hey, I completely understand your frustration – I once tried to replace the edge banding on an Ikea Billy shelf myself and was really annoyed when the band started peeling off again after just a few weeks.
What helped me was first thoroughly removing all the old glue residue and then lightly sanding the edge with fine sandpaper. This improves the adhesive’s grip.
Otherwise, I recommend using really high-quality edge banding and applying it with a good iron – switch off the steam function, as too much heat can damage it.
Sometimes it’s also worth applying a thin tape or contact adhesive as a base before ironing on the banding to ensure it sticks properly.
I wish you good luck, I know how annoying this can be!
kemeo68
17 Dec 2021 07:49
nojaus schrieb:
What helped me was first thoroughly removing all old adhesive residues and then lightly roughening the edge with fine sandpaper.
That is certainly a sensible start, but honestly – who wants to spend the whole day ironing on and gluing edge banding when you could simply replace the board?
I think the Billy shelf is so inexpensive that it almost seems unreasonable to invest effort into such repairs. I find the idea of sealing the edge nice, but ultimately the time factor is decisive.
For those who still want to go through with it, I would recommend using proper two-component (2K) adhesive and professional edge banding. The standard PVC edge banding from Ikea is basically not worth considering.
tyson51
17 Dec 2021 09:31
I would like to add that mechanical preparation of the edge is essential for adhesive surfaces to hold permanently.
Roughening the edge is important – but not too coarse, as this can damage the laminate.
I also recommend cleaning the surface with a degreasing cleaner to remove any traces of grease or dust.
Regarding edge banding: there are edge bands with meltable PUR adhesive, which are significantly more durable than simple PVC bands with EVA adhesive.
Those with some DIY skills can also use liquid edge strips in the form of acrylic sealant or special wood protection varnishes, which provide a smooth, durable surface after drying.
Thierryzar
17 Dec 2021 11:05
Attach thin sanding paper.
Apply edge banding with an iron suitable for value-for-money use.
Trim edges and seal with wood glue or contact adhesive.
chen67
17 Dec 2021 14:29
I agree with the tips and would like to add something: If you don’t want to rely on PVC edge banding, try self-adhesive veneer. It comes in various wood finishes and, with proper preparation, it sticks really well.
Don’t forget to sand first, then smooth the edge with a squeegee to avoid any air bubbles.
Plus: It looks very high-end, almost like something from an expensive furniture store.
It takes a bit of skill, but it’s definitely fun! 😉
