ᐅ Problem Solving: Retrofitting Fabric Doors for Kallax Units – Is It Worthwhile?
Created on: 31 May 2021 08:47
tidadraHello everyone, I’m considering upgrading my IKEA Kallax shelves with fabric doors, mainly because the wooden doors are a bit too heavy and inflexible for my needs. I’m aware of other fabric solutions, like curtains, but I wonder if the effort is really worth it: Are fabric doors practical and durable enough for everyday use to be a genuine alternative to the original Kallax doors? I’m looking for a sturdy and visually appealing solution that is easy to install, preferably something DIY. Has anyone had experience with fabric doors for Kallax and can share pros and cons from personal use? Which types of fabric have proven reliable, and how about cleaning? I look forward to your opinions and tips!
Fabric doors work well when they are tightly stretched and combined with a frame or track. For installation, Velcro or magnetic strips that can be easily stuck on are suitable. For a durable fabric, I recommend canvas or a heavy upholstery fabric. Cleaning is best done with a removable cover that fits in the washing machine.
Retrofitting fabric doors onto Kallax shelves can be quite practical, provided some technical details are considered. First, it is important that the fabric maintains sufficient tension; otherwise, wrinkles and a sloppy appearance will occur. I recommend constructing a sturdy wooden frame (e.g., from 2x2 cm (1x1 inch) battens) to keep the fabric taut and also serve as a guide.
There are various options for attaching the frame to the shelving unit: magnetic strips, narrow rails, or strong hook-and-loop fasteners (Velcro). It is also important that the fabric is durable and tear-resistant; canvas or upholstery fabrics with a high polyester content are suitable. Pure cotton can wear out quickly.
Cleaning can be challenging if the fabric is sewn on permanently, so removable covers are advisable. Alternatively, protective coatings or impregnations can be applied beforehand to make the surface more resistant.
From personal experience, I also recommend considering how often the doors will be opened: fabric doors are not as durable under daily heavy use as wood or MDF doors. However, they are quite suitable for decorative or light-use purposes.
JORGERON schrieb:
Fabric doors work well when they are tightly stretched and combined with a frame or track. That may be true, but I wonder if the visual improvement is really that significant when adding a frame to the Kallax unit.
Laukau5 schrieb:
From my own experience, I also recommend considering how often the doors will be opened: fabric doors are not as durable under daily, heavy use compared to wood or MDF doors. A very important point. Additionally, there is often a lack of privacy when the fabric is too thin – this should also be considered, especially if the shelf is used for a lot of storage and you prefer not to have certain items openly visible.
Is there actually a fabric that is both durable, opaque, and easy to handle? I find that combination difficult to achieve so far.
flo-Theres1 Jun 2021 07:32The topic of fabric doors for Kallax units is actually more complex than it appears at first glance. An important aspect I want to add concerns the installation and choice of fabric.
Here are my experiences:
- A frame is almost essential for keeping the fabric taut. A simple wooden frame that matches the door dimensions exactly and is made from lightweight material (e.g., pine) is usually sufficient. This prevents wrinkles and gives a more premium look.
- The fabric itself should not be too thin but still breathable to prevent mold growth behind the door. Polyester-linen blends work very well, are easy to maintain, and look elegant.
- The option to remove the fabric for cleaning is invaluable. Therefore, a clip-in or Velcro system is recommended, allowing the cover to be taken off and cared for separately.
A self-explanatory fastening method using magnetic elements has also proven practical. Depending on the load, transparent plastic strips can be used as an alternative.
In conclusion, my takeaway is: fabric doors are definitely a practical and visually flexible option—if you consider the points mentioned above. For heavily used areas or doors with high traffic, however, I would still prefer doors made of solid material.
PECLARISSA2 Jun 2021 10:05I think the idea of upgrading Kallax shelves with fabric doors is really charming and practical—especially if you want a softer look and more flexibility quickly! 🙂
Of course, it’s not as sturdy as wood, but this has that DIY charm and mainly serves as decorative storage protection. Keeping it clean is also quite easy with a removable cover.
So: thumbs up for flexibility and appearance! For maximum durability, probably not. 😉
Linavin schrieb:I’ve had good experience with canvas. It’s durable, opaque, and feels nice to the touch. Plus, it’s wonderfully versatile, sometimes even with a pretty pattern.
Is there actually a fabric that is both durable, opaque, and easy to handle? I find that hard to combine so far.
