ᐅ Designing and Sturdily Building IKEA Metod Kitchen Islands Yourself with Plenty of Storage Space
Created on: 8 Nov 2023 09:42
jupote
jupote
8 Nov 2023 09:42
I am currently planning an IKEA Metod kitchen island and want to build it as sturdy as possible while maximizing storage space. The idea is for the island to serve not only as a central work surface but also to provide plenty of room for pots, pans, and supplies. I want to combine the standard modules effectively and possibly add some extras to ensure everything holds well and the structure is robust – especially since I plan to use countertops made of thicker material.
Does anyone have experience designing such islands, particularly with regard to stability and optimizing storage? Are there any tips for additional reinforcements or smart combinations of the Metod base cabinets?
I look forward to your input and also any advice on common mistakes to avoid.
Nabla64
8 Nov 2023 10:11
Hello jupote,
You have chosen a very good question because it focuses directly on the key aspects of a Metod kitchen island: stability and storage. To address the topic systematically, here are a few pointers:
- First, the selection of the base cabinets is crucial. For a stable island, 60 cm (24 inches) wide cabinets with reinforced side panels are better suited than narrow modules.
- The connection between the modules can be done using the original Metod connector clips – these already provide good stability, but I recommend reinforcing them further with additional brackets on the back or bottom panel.
- The countertop is also an important factor: if you use a thicker countertop, such as a 3.8 cm (1.5 inches) thick solid wood or stone slab, it puts more stress on the structure. Therefore, it makes sense to add cross braces made of wood or aluminum under the countertop.
- For more storage space, you can choose drawer inserts or internal pull-outs. Tall cabinets or open shelves as additional elements beside the island can also help increase the surface area.
- A common mistake is designing islands that are too large without sufficient support, causing them to tip or wobble.
Summary: Choose wide, sturdy base cabinets, mechanically reinforce the modules, plan cross braces under the countertop, and use efficient internal storage solutions. If you like, I can also provide a small sketch or a list of recommended modules.
andre3
8 Nov 2023 12:07
I would like to clarify this: While these clips are sturdy, they may not always be sufficient for kitchen islands, especially when dealing with larger dimensions. I recommend additionally installing metal angle profiles on the inner edges of the base cabinets.
Likewise, the countertop should be properly secured, for example with screws from underneath the base cabinets, to prevent it from shifting. Regarding storage planning, IKEA drawers with soft-close function are highly recommended, as they offer better organization than standard doors.
Finally, a note: To ensure the island does not wobble, consider checking for additional floor fastening—such as a central support leg—if the island is very long or has an overhang.
GALENKU
8 Nov 2023 14:59
If you want stability, use Metod cabinets with metal frames for the base. Avoid too many open shelves, as this reduces rigidity.
For plenty of storage space, I recommend drawer inserts and making optimal use of the depth.
Z
zarHenning
9 Nov 2023 07:26
You should not plan the island too large. A maximum length of 2 meters (6.5 feet) is recommended; otherwise, support legs will be necessary. Additionally, I recommend securely fastening the countertop with angle brackets. Storage space can be effectively created using pull-out drawers inside the cabinets.
Layla
9 Nov 2023 11:18
jupote schrieb:
Does anyone have experience planning kitchen islands like these, especially regarding stability and optimizing storage space?
I understand your concern—building a kitchen island yourself can seem challenging at first, especially when you want it to be sturdy and provide enough storage. I built a Metod island two years ago and found it helpful to plan it step by step: first measure the dimensions, then choose the modules, and repeatedly check whether the joints are really strong enough.
For example, I reinforced the backs with extra boards, which gave me a very secure feeling. Also, you should really take your time measuring; it will save you a lot of problems later on.
Please let me know if you’re unsure about any step—finding a good solution is easier together.
